4wd pushbutton 5 spd
9 replies to this topic
#1 Vanislru
Vanislru
    Durka Durka!
  • 791 posts
  • Cumberland, BC
Posted 16 August 2005 - 04:39 PM
I'm trying to stuff a pb 4wd 5pd trannie into a twagon I have. Can I run 2 wires from the connector coming from stick shift to the 2 vac. sol.'s under the hood. I've got 4wd light sorted out, I just need to figure out how to actuate the sol.'s
#2 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 16 August 2005 - 11:01 PM
Should be 3 wires on the stick for the pushbutton. 1 power in, 2 power out. Those run to the hot side of the solenoids, then just ground the black wires off the solenoids and you're good to go.
#3 Vanislru
Vanislru
    Durka Durka!
  • 791 posts
  • Cumberland, BC
Posted 16 August 2005 - 11:22 PM
thanks! I searched but couldn't confirm this.
#4 bhamxt
bhamxt
    New User
  • Pip
  • 9 posts
  • bellingham
Posted 16 August 2005 - 11:31 PM
in a sort of related question, my 4wd light doesn't go on when I hit the button, it's not the fuse, have a digi dash, any ideas, thanks
#5 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 17 August 2005 - 12:09 AM
look up iluvdirt as he wired up the mechanism for a pushbutton 5spd using 2 toggle switches, for lack of a dp/dt switch
#6 mudduck
mudduck
    Subaru Nut
  • 708 posts
  • Asheboro NC
Posted 21 August 2005 - 10:57 AM
Just wondering, but can the pushbotton be converted to a lever shift? I haven't had any problems with mine engaging, but I just don't like pushing a bottun to engage the 4wd.
#7 TurboSPFI
TurboSPFI
    Banned
  • Banned
  • 374 posts
Posted 21 August 2005 - 11:00 AM
lever shift for a single range? you might as well just get a d/r
#8 mudduck
mudduck
    Subaru Nut
  • 708 posts
  • Asheboro NC
Posted 21 August 2005 - 01:12 PM
I would have to find a d/r tranny around here, which is easier said than done in this neck of the woods, and I can't afford to have one shiped.
#9 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,087 posts
  • NH
Posted 21 August 2005 - 10:03 PM
A cable shift setup would be easiest, thats what the vacuum actuator moves to shift the tranny. take a look under the car, the actuator is on the left of the tranny with a cable leading to the right of the tranny.
#10 TurboSPFI
TurboSPFI
    Banned
  • Banned
  • 374 posts
Posted 21 August 2005 - 10:46 PM
Oh yeah I forgot, they're everywhere here.
