B99Brighton Posted August 19, 2005 Share Posted August 19, 2005 I'm looking to turbo charge my sub! any one know of a company that makes a kit to add a turbo to a NA engine. I got a 99 legacy with a NA 2.2L. I can't seem to find a company that makes a kit for my application. Also is there any problems with adding a tubo to a NA engine. will the internals take the extra punishment? Quote Link to comment Share on other sites More sharing options...
mattocs Posted August 20, 2005 Share Posted August 20, 2005 To have a long life with the engine, you'll want to find a turbo engine to put in the car. Do a search on the board and you'll see what all engine internals need to be replaced in order to have a decent amount of boost, and long engine life. Quote Link to comment Share on other sites More sharing options...
subyrally Posted August 20, 2005 Share Posted August 20, 2005 it would cost you about the same if not less to just do a wrx swap, or even a jdm legacy swap. last i checked, bolt on turbo kits are around $2500 and you can get turbo engine swap. that and a swap will last a lot longer than a bolt on turbo set up. Quote Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted August 20, 2005 Share Posted August 20, 2005 the only turbo kit i've seen is made by avo, and i think that it was around $4,500 to buy it, comes with everything you need to bolt on and go, but i think that it would probably be cheaper to do a wrx swap instead.... its up to you.... check http://www.rallitek.com for the turbo kit, thats the only place i have found it anyway..... Quote Link to comment Share on other sites More sharing options...
B99Brighton Posted August 20, 2005 Author Share Posted August 20, 2005 Thanks for the input guys. I'll keep researching it before I do anything! Quote Link to comment Share on other sites More sharing options...
