joeaxial Posted August 24, 2005 Share Posted August 24, 2005 Hi all, This is my first post to this great message board! I'm looking at purchasing a 1992 Subaru SVX with about 110,000 miles. The car looks pretty good, but the transmission will not shift from 2nd to 3rd gear. 1st, 2nd and reverse seem fine. I can pick up this car very cheap, but am wondering what it might cost me to get the trans fixed. Could it just be something electrical? Thanks, Steve Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 24, 2005 Share Posted August 24, 2005 i'd plan on getting another transmission. start looking around, asking for a used one and you can get a decent price on one. rebuilds or new they can be very expensive. but used ones run 1,000 - 2,000 easy as well from a yard. you can get better prices. i think you can even get other transmissions (more available subaru transmissions....= cheaper) but i'm not sure of the details on which models will work. install a transmission cooler when you get another trans so you can hopefully avoid this in the future. heat kills these transmissions, very common. ATF cooler helps tons and costs 29.99 or less and super simple to install. Quote Link to comment Share on other sites More sharing options...
joeaxial Posted August 24, 2005 Author Share Posted August 24, 2005 Gary, thanks for the advice. Does anyone know if you can use the 4EAT trans from other subaru models in the SVX? Quote Link to comment Share on other sites More sharing options...
camosuba Posted August 25, 2005 Share Posted August 25, 2005 the svx trannies are the better ones around that time they are stronger in the clutch pack apparently. Quote Link to comment Share on other sites More sharing options...
mattocs Posted August 25, 2005 Share Posted August 25, 2005 I believe a manual tranny from the Legacy will bolt up easy. Just a suggestion Quote Link to comment Share on other sites More sharing options...
