All the warning lights---
14 replies to this topic
#1 pyromanic
pyromanic
    Subaru Fanatic!
  • 486 posts
  • Central Oregon
Posted 25 August 2005 - 04:22 PM
aross the bottom of the dash came on today! Just before everything lit up red, the tach got a bad case of the twitches. The needle was twitching like a tweaker coming down off a long run. Also, voltmeter in dash is now reading like 8 volts, revving motor makes no difference. However, now tach needle seems to to be working better! WTF is going on??
I'm like super busy right now with a huge carpentry project, didn't have time to do more that pop the hood and wiggle the battery terminals. They seem tight.
Edit: Ok, I just went out and cleaned the batt terminal, to no avail. Tach seems fine now, but she's only running on like 8 volts.
I'm guessing I've fried an alternator, but that's just a guess.
Any ideas apprecieated.
Thanks
Pyro
#2 samo
samo
    Boo.
  • 731 posts
  • The Emerald City
Posted 25 August 2005 - 04:24 PM
Sounds like it's time for a new alternator.
#3 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 25 August 2005 - 04:26 PM
I second that motion.
#4 pyromanic
pyromanic
    Subaru Fanatic!
  • 486 posts
  • Central Oregon
Posted 25 August 2005 - 04:39 PM
You guys are great. Talk about an imediate response!
Thanks. I've got a couple sitting around.
Pyro
#5 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 25 August 2005 - 07:23 PM
Yeah, when the alt goes dead all your warning lights will illuminate.
-Brian
#6 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 25 August 2005 - 10:49 PM
The lights will also come on if the ground wire for the instrument cluster comes loose. You may want to check that.
#7 jeffast
jeffast
    f*** im 24
  • 2,029 posts
  • midwestren
Posted 25 August 2005 - 11:34 PM
i'd have to agree the alt sounds like the culprate
#8 Tin Soldier
Tin Soldier
    Wannabe awesome guy.
  • 555 posts
  • Franklin, PA
Posted 26 August 2005 - 09:23 AM
Ditto!
Been there and done that.
#9 mudduck
mudduck
    Subaru Nut
  • 708 posts
  • Asheboro NC
Posted 26 August 2005 - 04:02 PM
Sounds like the alt. I been having problems with mine also, but none of my lights will light up real bright, and voltage has been running normal, tahn dropping down to 9-10 volts. Going to toss in anouther alt and see if that helps.
#10 KStretch55
KStretch55
    Subaru Fanatic!
  • 370 posts
  • Boise County
Posted 26 August 2005 - 04:11 PM
When mine went out a few weeks ago, no lights came on, and the voltmeter just slowly began to drop, until at roughly 9 volts it wouldn't run anymore. Funny that I didn't get any lights. Also, of note, the idiot lights didn't light with the key in "run" either. With the exception of the CEL. It did light in "run".
#11 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 26 August 2005 - 04:17 PM
Depends on what goes out inside the alternator. You'll get different symtoms with diaods blowing out vs the voltage regulator going out.
#12 pyromanic
pyromanic
    Subaru Fanatic!
  • 486 posts
  • Central Oregon
Posted 26 August 2005 - 08:58 PM
I popped in a spare alt today, and all seems fine, though I only had time to drive it a mile or so. Hope it was just that the alternator was old (it was) and not something else that "caused" alternator failure. (I don't even know if that situation is possible)
thanks guys,
Pyro
#13 samo
samo
    Boo.
  • 731 posts
  • The Emerald City
Posted 26 August 2005 - 09:45 PM
A really dead battery or a huge electrical drain can kill an alt in a hurry too. As long as those aren't issues, old age is mostly what gets them.
#14 noob2soob22
noob2soob22
    USMB Regular
  • PipPipPip
  • 124 posts
  • Marshall, MI
Posted 27 November 2012 - 11:21 PM
where might I find this ground on an 83 ea81 wagon?
#15 naru
naru
    1000+ Super USER!
  • 2,299 posts
  • under the bridge
Posted 28 November 2012 - 12:48 AM
Under the fusebox.
