using the fwd option
12 replies to this topic
#1 bdecriscio
bdecriscio
    USMB Regular
  • PipPipPip
  • 55 posts
  • altoona pa
Posted 27 August 2005 - 08:37 PM
I recently put a fuse in my daughters 96 imprezza (to make it fwd) for a short term fix till she could afford new matching tires. Reading through all the older posts regarding awd and mismatched tires, I'm not sure if I'm causing more damage or not by doing this. Does using the fwd option help avoid damage to the transmission or does it cause damage by being used iappropriatly?
Thanks, Bob
#2 mattocs
mattocs
    Subaru Legacy Lover
  • 1,312 posts
  • Pittsburgh
Posted 27 August 2005 - 08:56 PM
Don't do it forever. If you have to do it until you get the money together for new tires, it outta be ok.
#3 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 28 August 2005 - 11:00 AM
Over extended use of the FWD fuse can possibly lead to premature failure of the duty c solenoid. You should be alright for now, but I would try to scrape together the money for tires as soon as you can.
#4 L67cooled
L67cooled
    New User
  • PipPip
  • 14 posts
  • B town
Posted 30 August 2005 - 12:31 PM
How do you do this? Where is this fuse?
#5 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 30 August 2005 - 04:08 PM
On the older models the fuse holder is next to the passenger strut tower in the engine bay.
On the newer models I believe it's in the fuse box in the engine bay.
#6 Sydfloyd44
Sydfloyd44
    USMB is life!
  • 153 posts
  • Central PA
Posted 30 August 2005 - 06:21 PM
Was visiting a friend in Ft Myers Beach about 4 months ago and his 97 Outback has the torque bind issue. Been thru the dealer thing about 4 times and it just returns. When I was there, I did some reading on the board here and the opinions were somewhat mixed as far as exactly what "long term" is and what type of damage will result. (was concerned about him driving it back to PA with the fuse in)
Regardless, I put the fuse in for him and he was RELIEVED to have it stopped. Shortly after that, he moved back to PA to his summer home driving I95 the whole way and has been driving with it in for at least the last 2 months with NO problems or issues to speak of. When I went to visit, just to see what would happen, we pulled the fuse. Torque Bind was obviously still there but after about 20 miles of driving, was clearly no worse than when we originally put the fuse in. He is leaving for his annual trip to Thailand in a couple of days but I just spoke to him and he now has his eye on the Tribeca.
#7 Sydfloyd44
Sydfloyd44
    USMB is life!
  • 153 posts
  • Central PA
Posted 30 August 2005 - 06:24 PM
On his 97 Outback, it is easy to find. Looking under the hood, look just right of the passenger side strut tower. Sticks up out of no where. Black with white writing, FWD. Pop the cover and stick in the fuse. (15 amp I think)
#8 LosDiosDeVerde86
LosDiosDeVerde86
    1000+ Super USER!
  • 1,358 posts
  • Columbus
Posted 30 August 2005 - 06:36 PM
but wouldn't mismatched tires cause that as well?
#9 friendly_jacek
friendly_jacek
    Subaru Nut
  • 644 posts
  • USA
Posted 31 August 2005 - 01:01 PM
No.
#10 LosDiosDeVerde86
LosDiosDeVerde86
    1000+ Super USER!
  • 1,358 posts
  • Columbus
Posted 31 August 2005 - 03:48 PM
No.
but unmatched tires may be different physical sizes which would cause awd problems.
#11 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 31 August 2005 - 04:34 PM
Mis match tires can cause torque bind due to wheel speed differences. Torque bind when left alone I think is more likely to cause issues to the clutch plates, rather then the duty c solenoid, but I can't say for sure that the duty c solenoid wouldn't be affected by driving extended periods with mismatched tires.
#12 LosDiosDeVerde86
LosDiosDeVerde86
    1000+ Super USER!
  • 1,358 posts
  • Columbus
Posted 31 August 2005 - 04:54 PM
so i keep rpetending that know what the duty c selonoid does...but i don't
and no.. i havn't done a forum search for it.
#13 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 01 September 2005 - 11:59 AM
Basically it controls the amount of lockup on the rear clutch plates....so essentually controlling AWD.
Check out these scans, they may explain it better.
http://www.main.expe...fer_system1.jpg
http://www.main.expe...fer_system2.jpg
http://www.main.expe...fer_system3.jpg
