75subie Posted August 28, 2005 Share Posted August 28, 2005 i found a cheap 99 forester that needs a transmission, but the only local trans i can find is out of a 99 outback.they are both automatics.would the outback tranny bolt up the same?any info is appreciated Jon Quote Link to comment Share on other sites More sharing options...
subeman90 Posted August 28, 2005 Share Posted August 28, 2005 it will bolt up. the only diff might be the rear diff ratio. Get that from the doaner too and you should be good to go. Quote Link to comment Share on other sites More sharing options...
75subie Posted August 28, 2005 Author Share Posted August 28, 2005 thanks for the info subeman i wonder if the forester axles will fit in an outback diff? i did also find a 02 forester tranny, but it is listed as being different from a 99???? thanks Jon Quote Link to comment Share on other sites More sharing options...
subeman90 Posted August 28, 2005 Share Posted August 28, 2005 I think the 02 is a 4.11 and the other is a 4.44 ratio... don't hold me to this though. Quote Link to comment Share on other sites More sharing options...
75subie Posted August 28, 2005 Author Share Posted August 28, 2005 thanks Matt, i will try getting the tranny and diff out of that outback.actually, the outback is in your neck of the woods (Harry`s upullit).thanks Jon Quote Link to comment Share on other sites More sharing options...
subeman90 Posted August 28, 2005 Share Posted August 28, 2005 I love that place.... I haven't been there for a few years. I'm not too much closer to that place than you are Have a blast up there...that place is a sight! Quote Link to comment Share on other sites More sharing options...
tacode Posted August 29, 2005 Share Posted August 29, 2005 Out of curiosity, how much did the replacement transmission/diff set you back? My '99 Forester has the hesiation issue, which has gotten better with more regular fluid/filter changes, but one day, I'll be looking! I'm still debating whether to dump it or fix it. Quote Link to comment Share on other sites More sharing options...
75subie Posted August 29, 2005 Author Share Posted August 29, 2005 i missed the forester:banghead: it was a 2000 with the s package for $1800, but i waited too long.i bet harry`s wouldn`t charge more than $120 dollars for everything, but you would have to pull it yourself.take care, Jon Quote Link to comment Share on other sites More sharing options...
