Rear anti-sway bar
6 replies to this topic
#1 Beavis
Beavis
    New User
  • PipPip
  • 24 posts
  • california - san luis obispo
Posted 29 August 2005 - 06:23 PM
I found a RX in the junkyard today, and grabbed the LSD. It's a different ratio than my GL-10 diff, but I'm sure I can find a home for it.
The RX had a rear anti-sway bar. Anybody know if this will fit my GL-10 wagon? It looks like I'd have to do a bit of welding to attach it to the control arms, but that's no problem. It's a pretty skinny bar - is it worth my time?
#2 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 29 August 2005 - 07:32 PM
well if your GL-10 is a turbo, then the rear diff should be the same ratio (3.70) compared to the non turbo diff which are 3.90.
As for the rear swaybar, yes it will fit with no mods at all, plus since its larger, it will make your wagon handle better in turns
#3 Subi81
Subi81
    1000+ Super USER!
  • 1,009 posts
  • Ventura, Ca
Posted 29 August 2005 - 08:06 PM
Ummm. not sure about that Caboobaroo
I have ONLY seen one GL-10 that had the tab mounts for the rear sway bar. If you have the mounting tabs then yes it is a direct bolt on. I had to take off the rear passenger tire to get my bar on though.
Since I didn't have the mounting tabs I had to use the trailing arms from an RX. The only other way is to weld the tabs on.
I totally agree the sway bar will make it handle better. Less body roll.
#4 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 29 August 2005 - 08:28 PM
I agree.. I have only seen one GL-10 with the rear bar as well.. Thankfully, I happen to own that one:D
Use the RX trailing arms and it becomes a bolt on accessory
#5 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 30 August 2005 - 12:35 PM
I thought all GL10s had a rear sway bar?
#6 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 30 August 2005 - 03:26 PM
I have owned 5 87-88 GL-10s now
My white wagon is the only one with the rear swaybar so far. I have checked 4-5 more.. same result
#7 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 31 August 2005 - 12:21 AM
hmm I guess oen learns something new almost every day
I'm guessing its like the rear disk brake thing, only standered on turbo GL10s
