plueders Posted August 30, 2005 Share Posted August 30, 2005 I have a 2004 outback H6 that has 26000 miles on it. It is up to date on all of the service items. The car has a hesitation when I am going about 65 mph and up a slight grade. The car feel as if something is slipping. It does not do it all of the time. I took it to be serviced and they flashed the ECU. That seemed to reslove the issue for 2 days then it happened again. The service center has been real good about trying to resolve this problem, however they are not able to duplicate the problem. Does any one have any suggestion that I can give to the service center? Quote Link to comment Share on other sites More sharing options...
sea#3 Posted August 30, 2005 Share Posted August 30, 2005 Check the engine connector on the right hand side of the engine , the one that goes to the right shock tower , Check it for any corrosion ,also check the terminals Hope that helps SEA#3 Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted August 30, 2005 Share Posted August 30, 2005 Welcome to the board. My Subie hesitates on hills with the A/C on. Nothing big just enough to let me know it's not happy. With it off it seems to run fine. Check and see if it's related to the A/C. Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester--doesn't like A/C Quote Link to comment Share on other sites More sharing options...
