piloto Posted August 31, 2005 Share Posted August 31, 2005 Hello, I own a Subaru Legacy 4WD 1993, the automatic transmission ( TZ102ZR2aa-MM) has malfunctioned so I replaced it for a second hand gear including the frontwheel differntial, however I´m not sure what model (TZ102ZSAAAA-C3) is. Now whenever I speed the accelerator I can feel the front wheels skidding. Is it posible that the relation between front and back wheels is different? Has anybody information about the relation gear of the two automatic transmisiion I mentioned? Thanks!!! Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted August 31, 2005 Share Posted August 31, 2005 It's very possible the front and rear diff ratios are different. If you continue to drive it, you're going to kill the transmission again. You should be able to put a fuse in the FWD fuse holder next to the passenger side strut tower (on a left hand drive car). This will temporarily disable the AWD. Do you know what year car the new transmission came out of? Quote Link to comment Share on other sites More sharing options...
piloto Posted August 31, 2005 Author Share Posted August 31, 2005 thanks!!! No, I only have the part number TZ102ZSAAAA-C3 and I have not been able to find more information from it. It's very possible the front and rear diff ratios are different. If you continue to drive it, you're going to kill the transmission again. You should be able to put a fuse in the FWD fuse holder next to the passenger side strut tower (on a left hand drive car). This will temporarily disable the AWD. Do you know what year car the new transmission came out of? Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted September 1, 2005 Share Posted September 1, 2005 You may want to check on www.bbs.legacycentral.org I think someone was asking for a transmission decoder from that number.....and I don't recall it was answered or not. Quote Link to comment Share on other sites More sharing options...
