what ej heads can be swapped
3 replies to this topic
#1 LPGsuperchargedBrumby
    Fully retarded and low on compression
  • 665 posts
  • Dunedin, NZ
Posted 01 September 2005 - 02:22 AM
like the title says,im wanting to know what heads will swap with what...am i right in thinking all sohc heads will swap with all other sohc heads and that its the same with dohc heads...but that sohc and dohc won't interchange with each other.
i more interested in sohc stuff but it would be nice to know if i could slot sohc heads on a dohc block, as the dohc blocks a way easy'r to get hold of
#2 offroadsubaruguy
offroadsubaruguy
    Subaru Nut
  • 729 posts
  • arvada, colorado
Posted 01 September 2005 - 05:49 AM
subaru's are like legos. you can interchange just about everything. all sohc heads can interchange with each other, and all dohc heads can interchange with each other, you can even swap a sohc setup for a dohc setup. every single one of the ej motors is the same block, just different amounts of bore and stroke make up the larger motors...
#3 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 01 September 2005 - 12:06 PM
Before anyone says anything will swap with anything.....what year/model engine do you have, and what are you looking to swap.
Whether the engine is n/a or turbo brings in complexities, as well as what phase it is, exhaust port (single or dual port), intake manifold fitment, etc.
#4 blitz
blitz
    Banned
  • Banned
  • 1,091 posts
  • Warren, Michigan
Posted 01 September 2005 - 08:55 PM
You'll need to be concerned with the resulting compression ratio because the larger displacement motors have greater combustion chamber volume.
I think that if you swap a set of 2.5 heads onto a 2.2 you'll drop the compression and up the flow - great for a F/I buildup, but not good for a N/A buildup.
