timing belt(s) for 93 impreza 1.8L
I've taken my 93 impreza 1.8L to a mechanic friend to see about getting the timing belt & front crank seal replaced. He says there are actually two timing belts and that he'd need a special tool to replace them. Can anyone tell me if he's correct, or perhaps has looked up the wrong car or model. I know the 85 wagon I had once had a dual timing belt...just wondering if the 93 impreza is the same way. Thanks for the replies!!
The Impreza 1.8 is an EJ motor. It is nearly identical to the 2.2. (also an EJ motor). The Timing belt parts and components are the same. The job is the same.
The EA series 1.8, from earlier cars, is what you are confusing your Impreza with.
Todd
