draggon Posted September 3, 2005 Share Posted September 3, 2005 hey guys needing a little help again,got the timingbelts changed last week and the soobie is running great,my new problem is,i pulled out of this guys driveway and i hear a really loud cluck,so i check it out and im sure of the technical name,i left my soobie manual at jims house,anyway the tubing that runs from the drv.side to the pass.side,a freind called it the frame,but i dont think its the frame,it connects to the shock and a-arm,its about 3" in diameter,well my question is,how long should it take to replace,jim has a spare but not sure if its the right one,are they all the same,oh its FWD,any help would be greatly appreciated.i didnt have my camera with me or i would have posted pics. Quote Link to comment Share on other sites More sharing options...
Humble Nuto 53 Posted September 3, 2005 Share Posted September 3, 2005 hmmmm, you have the steering rack going across from wheel to wheel...fat in the middle rubber accordion boots on the ends then skinny rods to the wheels sube doesnt have any round frame components only other parts i can think of would be the drive axels, one on each side and the suspension struts, but they stand up not lay across... Quote Link to comment Share on other sites More sharing options...
Turbone Posted September 3, 2005 Share Posted September 3, 2005 Can you come up with some more details? Theres alot of grey area in your explanation :cool: Quote Link to comment Share on other sites More sharing options...
calebz Posted September 3, 2005 Share Posted September 3, 2005 maybe the sway bar? It goes from one side to the other, but is only 16-17mm thick Quote Link to comment Share on other sites More sharing options...
draggon Posted September 3, 2005 Author Share Posted September 3, 2005 lets put it this way,when looking at the car from the rear,my drv.side rear tire leans in at the top,and rubs the spring.the spring comes down to the what? and that goes to what?<--- this what is what broke,like i said i left my manual at jims and cant check the proper name,it looks about 2 1/2"-3" in diameter,its not straight,it has bends in it,but leads to the pass.side,it possible it could be a sway bar,ive just never seen one that big lol Quote Link to comment Share on other sites More sharing options...
draggon Posted September 3, 2005 Author Share Posted September 3, 2005 does anyone have a pic. of a sway bar,i'll know it when i see it. Quote Link to comment Share on other sites More sharing options...
Humble Nuto 53 Posted September 3, 2005 Share Posted September 3, 2005 ewww, the rear suspension tube? not heard of that coming apart before. would have figured the mounts would have rusted and collapsed into the body before that fat pipe failed... well theres tons of em in the junkyard, only a few bolts to remove it. but i still suspect you have terminal rust in other areas if that tube failed. you need an experienced and critical eye to look at your situation before you go invest any more money on this particular car in my humble opinion Quote Link to comment Share on other sites More sharing options...
draggon Posted September 3, 2005 Author Share Posted September 3, 2005 ewww, the rear suspension tube? not heard of that coming apart before. would have figured the mounts would have rusted and collapsed into the body before that fat pipe failed... well theres tons of em in the junkyard, only a few bolts to remove it. but i still suspect you have terminal rust in other areas if that tube failed. you need an experienced and critical eye to look at your situation before you go invest any more money on this particular car in my humble opinion rear suspension tube,now that sounds like what im seeing,if i have to i'll replace any steel that needs it,i love my soobie and im not ready to let her go lol,not just yet anyways lol Quote Link to comment Share on other sites More sharing options...
Humble Nuto 53 Posted September 3, 2005 Share Posted September 3, 2005 well commited you be then: it does unbolt. the entire assembly. somewhere in this mess i have photos someone else posted of the thing but im days behind finding them. it is just as easy as unbolting unbolting and installing. there are going to be snags im sure. brake lines dont need to be opened as far as i know. you can probably let the axels hang from the differential, it all depends on rust and if you can get yours off without breaking any bolts. in the junkyard you dont care if you break most of the actual bolts unless they are studs... a welded part of the assembly... i prefer U-pull yards, you get to learn what not to do on *their* stuff before you attempt your own. i would definitely start on your own car though and see if you can successfully (sp?) remove the broken part and then you will know if you want to go lay on your back in some junkyard. Quote Link to comment Share on other sites More sharing options...
draggon Posted September 3, 2005 Author Share Posted September 3, 2005 its FWD there shouldnt be a differential should there? Quote Link to comment Share on other sites More sharing options...
Subi81 Posted September 3, 2005 Share Posted September 3, 2005 Ok, ignore the differental and the driveline and this is what you should have under there. So what part is broken. Whoever took this picture is a geneius (s)! Thanks Quote Link to comment Share on other sites More sharing options...
draggon Posted September 3, 2005 Author Share Posted September 3, 2005 ok in the pic. i found,where its circled in red,but on the drv.side Quote Link to comment Share on other sites More sharing options...
Turbone Posted September 3, 2005 Share Posted September 3, 2005 Yup, thats the torque tube, or suspension tube. If that broke off on the end, you will need to replace the whole rear end. On a 2wd thats a major part of the suspension and without it, its real unsafe (if not impossible) to drive. But like Humble said, aint never seen one break before, not like that. The car must have come from a high road salt area, is all I can say You can remove the trailing arms from the main part of the suspension and then remove the tube and mounts. Quote Link to comment Share on other sites More sharing options...
draggon Posted September 3, 2005 Author Share Posted September 3, 2005 i'll have to ask jim where it came from,i bought it from him. Quote Link to comment Share on other sites More sharing options...
86subaru Posted September 3, 2005 Share Posted September 3, 2005 it came from a salt state, may not have a spare Quote Link to comment Share on other sites More sharing options...
draggon Posted September 5, 2005 Author Share Posted September 5, 2005 well got the old one off,and got another one from miles,yep hes here in ohio,for the weekend,anyway the new one had some cancerous holes so we filled them. Quote Link to comment Share on other sites More sharing options...
draggon Posted September 6, 2005 Author Share Posted September 6, 2005 well got the suspension tube replaced today,no thanks to jim lol,me get dirty no way ,then a freind(who jim kept calling freddy for some reason,freddie,freddie,freddie) i think the boy had,had a little to much coors,well anyway we start bleeding the brakes and freddie breaks off a bleeder,so i drive the car home about 3.5 miles,and proceed to break off a easyout in the caliper,DAMMIT!!! well i eventrally get it out,and slap a bleeder valve out of one of my probes,in and whala im done,hey jim cut down on the coors there buddy :-p Quote Link to comment Share on other sites More sharing options...
86subaru Posted September 6, 2005 Share Posted September 6, 2005 reason for not getting dirty was i had my good cloths on , hey turbo PIZZA MAN ,did the brake pedal get any stiffer Quote Link to comment Share on other sites More sharing options...
MilesFox Posted September 6, 2005 Share Posted September 6, 2005 where's my day old pizza? Quote Link to comment Share on other sites More sharing options...
draggon Posted September 6, 2005 Author Share Posted September 6, 2005 where's my day old pizza? hey where did you go there buddy,jim said you took off out of there like you had your panties in a bunch ,oh and hey stalker man(jim)were those your little house on the praire going to church clothes , Quote Link to comment Share on other sites More sharing options...
draggon Posted September 6, 2005 Author Share Posted September 6, 2005 did the brake pedal get any stiffer not on my way home,i got the old valve out, and put one in from one of my probes,i bled all 4 tires and now my pedal is better then before. Quote Link to comment Share on other sites More sharing options...
Turbone Posted September 6, 2005 Share Posted September 6, 2005 well got the old one off,and got another one from miles,yep hes here in ohio,for the weekend,anyway the new one had some cancerous holes so we filled them. Hmmm, swap out old rotten rear suspension, replace with another old rotten rear suspension Expect to replace it again sometime in the future. Quote Link to comment Share on other sites More sharing options...
draggon Posted September 6, 2005 Author Share Posted September 6, 2005 Hmmm, swap out old rotten rear suspension, replace with another old rotten rear suspension Expect to replace it again sometime in the future. yep thats about it,beggars cant be choosers,if i get 6 months out of this suspension i'll be happy,if it were any other type of car,no way,but the soobie is so easy,i'll do it again anytime. Quote Link to comment Share on other sites More sharing options...
86subaru Posted September 6, 2005 Share Posted September 6, 2005 no they were not church clothes , i was at a family gathering labor day , i know better than to wear nice jeans while working on cars + had to go to wapakoneta , later in the day , it seemed like you and freddie had everything under control , remember i charge for using my driveway ,i think it would look cool it you painted , TURBO PIZZA MAN on the side+ i did not know when you were coming back to work on it , i work 55-60 hrs a week ,soooo a long weekend is nice to do something with the family and not work on cars , which i did part of the weekend ,if the part was to rusty then why put it on ? you were lucky that there was a part here , + the other part , Quote Link to comment Share on other sites More sharing options...
draggon Posted September 8, 2005 Author Share Posted September 8, 2005 oh sorry,they sure looked like goin to church clothes,and your wifey told me they made you leave the family outing because you got drunk and was wondering around singing "i feel pretty,oh so pretty" Quote Link to comment Share on other sites More sharing options...
