CV Joints? Maybe??!?
Scrub2k
My Car (87 GL-10 Turbo) Makes a Wierd Noise when i drive it, it Sounds Kinda Like Something Metal Hanging Down on the Ground, I Was Told It Is the CV Joint, Anyone Have Any Experience With This Kinda Thing Or Any Other Ideas On What it Could Be? Its Bothering Me. Thanks
-Matt-
Matt,
Help us out! What else does it do?
Make Clicking noise on corners? Backing up?
CV boots split?
Where is the noise coming from?
Those of us with Inquiring Minds want to know.....:brow:
I'll go back to reading the National Inquirer now.....:slobber:
Glenn,
82 Hatch, transforming....:temper:
01 Forester, jealous......... :madder:
My Camry has had broken CV boots for 2 1/2 years and I still have not fixed them.:eek:
It dosen't make a sound......even on corners:cornfuzz:
Only Time it Makes any Sound is Going Straight When im Off the Gas, Nothing Out of the Ordinary When im on it, and it coming from around the Passinger Side Front Wheel, Sounds like a metal skidplate dragging on the ground, but there is nothin hanging down under the car.
:edit: the sound doesent change if im going around a corner or going straight only if im on or off the gas.
-Matt-
This wouldn't be a "Squeeler?" would it?
Check your brake pad depth?????
You may just need pads?????????
Look at your squeeler on your brake!
My Trooper will make screeches/squeels when I steer to one side of the street and not going straight or breaking.
Do some R&D on your brakes?????
Good luck,
Glenn,
88 Trooper...Squeeky
