bratsrus1 Posted September 8, 2005 Share Posted September 8, 2005 Hi Everybody This is Jerry,well i am trying to stuff a LSD in a 5 speed dual range tranny. I removed the LSD unit from the rear housing and the ring gear has 8 bolts on it. Well the ring gear from the 5 speed has 12 bolts on it they don't swap over. I was sure somebody has done this swap over. My question is what set up was used on the change over. Please let me know i need to get this tranny back together. Thanks Jerry Quote Link to comment Share on other sites More sharing options...
NorthWet Posted September 8, 2005 Share Posted September 8, 2005 The only one of which I heard was mudrat79's conversion, where he used a "phantomgrip" differential, not an FHI LSD. Quote Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted September 8, 2005 Share Posted September 8, 2005 whats wrong with using the ring gear from the lsd? shouldnt they both be the same size? Quote Link to comment Share on other sites More sharing options...
bratsrus1 Posted September 8, 2005 Author Share Posted September 8, 2005 Hi This is Jerry, the ring gear is smaller in the rear end than in the 5 speed. The ring gear in the rear end has 8 bolt holes and the 5 speed has 12 bolt holes. Thanks Jerry Quote Link to comment Share on other sites More sharing options...
calebz Posted September 8, 2005 Share Posted September 8, 2005 Sorry Jerry, it just doesn't fit.. A few people have torn them down to look, just like what you are doing, but I don't know of a single success in using the LSD chunk in the front diff. Closest thing is a phantom grip. Quote Link to comment Share on other sites More sharing options...
Storm Posted September 8, 2005 Share Posted September 8, 2005 http://forums.nasioc.com/forums/showthread.php?t=700370 This is for the newer generation of trannies, but if it will work for the older ones too...it's a viable option for light duty. Quote Link to comment Share on other sites More sharing options...
MorganM Posted September 8, 2005 Share Posted September 8, 2005 The only one of which I heard was mudrat79's conversion, where he used a "phantomgrip" differential, not an FHI LSD. And from what I've talked to John about; it's not a direct bolt in either. There is modifications required to make it fit. Quote Link to comment Share on other sites More sharing options...
bratsrus1 Posted September 9, 2005 Author Share Posted September 9, 2005 Hey Calebz This is jerry, just what is a phantom grip never heard of it. Let me know Thanks Jerry Quote Link to comment Share on other sites More sharing options...
Turbone Posted September 9, 2005 Share Posted September 9, 2005 Panty grip Quote Link to comment Share on other sites More sharing options...
