Mike_N_Austin Posted September 8, 2005 Share Posted September 8, 2005 I am replacing the head gaskets on my 99 Subaru (180K miles). It has a 2.5 SOHC. Couple of questions for those who have replaced gaskets or heads on these motors. (1) Has anyone used their original head bolts on a head install. And if so, have you run into any problems from doing this. I have been getting conflicting information regarding head bolts needing to be replaced (2) Has anyone used resurfaced heads that were shaved more than .005" ? and if so, have you had any issue's with them (3) Has anyone installed heads without following the torque procedure outlined in the FSM to a tee ? If not, were there any consequences ? Thanks in advance Quote Link to comment Share on other sites More sharing options...
The Dude Posted September 9, 2005 Share Posted September 9, 2005 Mike, a 1999 Forester XT? In 1999 the Forester came as a base model, an L, and a S. So, what gives? Quote Link to comment Share on other sites More sharing options...
Mike_N_Austin Posted September 9, 2005 Author Share Posted September 9, 2005 Mike, a 1999 Forester XT? In 1999 the Forester came as a base model, an L, and a S. So, what gives? My Bad. Is an S Model Quote Link to comment Share on other sites More sharing options...
Mike_N_Austin Posted September 9, 2005 Author Share Posted September 9, 2005 Any opinions/advice on my questions ? Thanks, Mike Quote Link to comment Share on other sites More sharing options...
tomson1355 Posted September 9, 2005 Share Posted September 9, 2005 (1) Has anyone used their original head bolts on a head install. And if so, have you run into any problems from doing this. I have been getting conflicting information regarding head bolts needing to be replaced Yes. Twice. Without ill effects, but only 20,000 miles so far. See this thread http://www.ultimatesubaru.org/forum/showthread.php?t=41751&highlight=head+bolts and many others on the topic. (2) Has anyone used resurfaced heads that were shaved more than .005" ? and if so, have you had any issue's with them Heads were shaved but I don't know how much. (3) Has anyone installed heads without following the torque procedure outlined in the FSM to a tee ? If not, were there any consequences ? I followed the FSM, though I wasn't overly careful about the 90 and 180 degree tightenings. So far, so good. Good luck, Tom Quote Link to comment Share on other sites More sharing options...
