I was just wondering if anyone has ever thought about trying this. Instead of using RTV or something else out of a tube, getting a large o-ring w/ rectangular cross-section and installing it into the groove of the cam case, kind of like the VC gasket.
Even if it is a little too small to go the whole way around the case, I don't think it would hurt to leave a gap at the top.
It might be tricky finding the right cross-section to give you the right compression on the o-ring. Maybe that's why Subaru never ended up doing it.
Do the newer Subarus (Legacy/Outback/Forester) use the same cam case setup as DL/GL/Loyale?
EDIT:spelling
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
DIY rubber o-ring for cam case?
Started by
stephenw22
, Sep 08 2005 05:33 PM
2 replies to this topic
#1
Posted 08 September 2005 - 05:33 PM
#2
Posted 08 September 2005 - 08:01 PM
As far as I know, the EJ engines combined the cam tower with the head.
If you use the proper sealant on the cam tower (Anaerobic gasket maker, NOT RTV), there should be little or no leakage. However, an actual O-ring type seal would be cool. They make kits for forming custom O-rings that include several feet of the ring material and some special glue to connect the ends with. You might be able to find one in the right size and make some gaskets that way. Just a thought.
#3
Posted 09 September 2005 - 08:04 AM
...They make kits for forming custom O-rings that include several feet of the ring material and some special glue to connect the ends with. You might be able to find one in the right size and make some gaskets that way. Just a thought.
I'll have to store this in my memory bank for future reference.
No matter what, it would save tons of time to be able to use an o-ring instead of a liquid sealant. Even if it didn't last quite as long, it would make it almost as easy as changing a valve cover gasket.
