ej primary turbo
1 reply to this topic
#1 LPGsuperchargedBrumby
    Fully retarded and low on compression
  • 663 posts
  • Dunedin, NZ
Posted 09 September 2005 - 12:35 AM
does anyone know if a primary turbo off a twin turbo ej20 would work as the turbo on an ea81/82?
i figger that if the primary ej turbo spools at low rpm thru to midrange then it should do the same on a ea...low rpm thru to top end due to the ea's lower rpm redline
#2 ausubaru92
ausubaru92
    Turbo Talker
  • 583 posts
  • Bowraville NSW Australia
Posted 09 September 2005 - 07:46 AM
I have thought of this too:brow:
But the question is,.. at what rpm does this primary turbo spool up on the ej?
This is the sort of turbo ive been thinking about putting on a NA block
Id like boost from before 2K rpm
But I could be dreaming:rolleyes:
Gannon
