dshaw Posted September 23, 2003 Share Posted September 23, 2003 You may remember me posting a question on this car before. I am still in the troubleshooting phase with it. I think I need to replace the computer/ECU but wanted your collective opinion... With Key On, Engine Off the check engine light does not illuminate. I checked the bulb and swapped it with a known working bulb. I ran a test sequence on it from Mitchell's. They say to check power on the #2 (red/blue) connector and if it has power with Key On, Engine off and the computer disconnected then I've either got a bad connection at #2 or a bad computer. The connection looks fine so I'm about to shop for a new computer but wanted your opinions. The only 'problem' is the cold idle/running performance - once the car warms up it runs okay. Should I get a new computer? Thanks! Damian Quote Link to comment Share on other sites More sharing options...
