Grrr No Power Under Stress
1 reply to this topic
#1 xoomer
    1000+ Super USER!
  • 1,139 posts
  • Burien, WA
Posted 15 September 2005 - 03:20 AM
I have no power when going up hills I am also hearing a loud clicking noise on the drivers side. possible coil?
bad timing whats up.... also when I try to staRT it takes a few turns and some gas... is my disty screwed.. I followed instructions.. or my coil.. it seems to have a slight miss while ideling./.
#2 Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 15 September 2005 - 08:48 AM
Sounds like your timing is off. Do you have a timing light? You also need to connect the green test plugs at the ECU (under the rear dash panel). Slight miss could mean plugs/wires/cap.
The clicking could be a CV joint going bad.
