Justy=Luv Posted September 19, 2005 Share Posted September 19, 2005 Can anyone recommend a mechanic for the San Jose, CA area? I don't want to go to a 'stealership' and my mechanic in Santa Cruz is sort of far. He was awesome. He even cleaned out a mouse nest on my Justy and all the decaptitae mouse babies. But I digress. So I need a mechanic in San Jose. Please help. My 1999 Legacy Outback wagon is leaking. Big surprise, huh? In addition to the normal oil leaks, the coolant is leaking very badly and leaving a trail of coolant everywhere I go. Also the car is shaking really bad whenever I use the brakes. Thanks in advance Quote Link to comment Share on other sites More sharing options...
cookie Posted September 19, 2005 Share Posted September 19, 2005 There is supposed to be a very good independent in the Palo Alto-Menlo Park area. I could try to find the name if that is close enough. Quote Link to comment Share on other sites More sharing options...
NV Zeno Posted September 19, 2005 Share Posted September 19, 2005 Try "Japanese Beetle" in Sunnyvale, or "Made In Japan" (I think he's on Winchester), in Campbell. Otherwise, Norm's in South Tahoe..he's far, but very good:) . Quote Link to comment Share on other sites More sharing options...
TheBrian Posted September 20, 2005 Share Posted September 20, 2005 Come to Buffalo, NY, where every mechanic is a Subaru mechanic. Not really, but most mechanics have worked on plenty of them. Your symptoms are those of common problems (hole in the coolant system, very easy to diagnose and fix. Possibly warped brakes?) and I bet your average Joe Mechanic would be up to the task. Still, I like to find mechanics with triple-digit IQs, as they're less likely to swap parts madly until the problem goes away. Quote Link to comment Share on other sites More sharing options...
Justy=Luv Posted September 21, 2005 Author Share Posted September 21, 2005 thanks everyone for your suggestions I went to Made in Japan in Campbell. They could not find the leak but they said it is burning coolant and I need to replace the head gasket. It sounds expensive anyhow. boohoo Quote Link to comment Share on other sites More sharing options...
Gnuman Posted September 21, 2005 Share Posted September 21, 2005 Can anyone recommend a mechanic for the San Jose, CA area? I don't want to go to a 'stealership' and my mechanic in Santa Cruz is sort of far. He was awesome. He even cleaned out a mouse nest on my Justy and all the decaptitae mouse babies. But I digress. So I need a mechanic in San Jose. Please help. My 1999 Legacy Outback wagon is leaking. Big surprise, huh? In addition to the normal oil leaks, the coolant is leaking very badly and leaving a trail of coolant everywhere I go. Also the car is shaking really bad whenever I use the brakes. Thanks in advance Well, how about me? Does "I come to you" sound close enough? Are we still talking about the Justy that you had serviced in Santa Cruise? Or are we talking about a different beast? The leaks should be fairly easy to diagniose and repair. The brakes I'd have to have a look at. . . Oh, I meet the qualifications mentioned in the post above, and I specialise in Subarus. Send me a PM or email (both can be found in my profile by clicking on my name), and I'll reply with my phone number so we can set up a time. I service an area 100 miles in radius from either SF or Sac. You fall in that range. . . (I will not go 100 miles west of SF though, unless you provide the boat) Quote Link to comment Share on other sites More sharing options...
