Weak and ineffectual brakes......
8 replies to this topic
#1 bella
bella
    USMB is life!
  • 225 posts
  • Bucharest
Posted 19 September 2005 - 02:13 AM
Hello,
This is my problem:yesterday I have changed my brake pads. Because I didn't now how to push back cylinder to make more space for the new pads, I depleted it from brake fluid and late I learned that cylinder must be rotated to recede into the background. Now after brake aeration(only on that side with depleted cylinder-front right side-This could be the problem,...Should I bleed the others 3,...and the brake pump?????:banghead: ) my brakes are more, more weak and ineffectual that before....Please give me an advice...Thank you allot.:banghead::banghead:
#2 Snowman
Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 19 September 2005 - 02:23 AM
It sounds like you need to bleed the brakes.
#3 Humble Nuto 53
Humble Nuto 53
    User Awaiting Email Confirmation
  • 353 posts
  • squaresville baby
Posted 19 September 2005 - 02:24 AM
take it apart, and do it right.
screw the parking brake thingies back in, then properly bleed the entire system.
#4 bella
bella
    USMB is life!
  • 225 posts
  • Bucharest
Posted 19 September 2005 - 02:42 AM
Please :confused:tell me how exactly bleed the entire system. What is the procedure. Thanks.:confused:
#5 Blue Hornet
Blue Hornet
    New User
  • Pip
  • 2 posts
  • Novi
Posted 19 September 2005 - 06:00 AM
1. Go to an auto store and buy self-bleed tool. there are two kinds
a. ($7) a small tank with a one-way valve - you hook it up to the bleeder valve, open the valve some, and press the pedal yourself.
b. ($30) a hand pump that pulls the fluid out.
Both should have instructions.
2. Go to a search engine and type "how to bleed brakes, " and press Go.
DO NOT FORGET - Start at the brake that has the longest line to the master cylinder: usually the right rear.
#6 bella
bella
    USMB is life!
  • 225 posts
  • Bucharest
Posted 19 September 2005 - 09:51 AM
Thank you guys.....
Any other informations will be apereciated......
#7 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,270 posts
  • Everett, WA, USA
Posted 19 September 2005 - 09:45 PM
Subies have a different order
Front left
Rear Right
Front right
Rear Left
That is straight out of the 87 Factory service manual.
#8 bella
bella
    USMB is life!
  • 225 posts
  • Bucharest
Posted 22 September 2005 - 05:20 AM
So,....should I bleed the brake pump(the MC) too????Because tomorrow I want to do this action.
Thanks
P.S. When I press the brake pedal a very easy anomaly is happen with my engine...is not working so fine at idle state...any guess??? There is a vaccum leak??
#9 zyewdall
zyewdall
    Subaru Master
  • 2,136 posts
  • Ward, CO
Posted 22 September 2005 - 09:57 AM
Question on brake feel on the EA81 wagons. I've owned two of them, and both had brakes that you had to give one pump before putting your foot into it. Sort of like it wasn't completly bled. But I did bleed both according to the manual. Has anyone else experienced this? My EA82 wagons don't feel this way -- firm pedal on the first push.
