carfreak85 Posted September 24, 2003 Share Posted September 24, 2003 My turn signals and hazards will not work and the reason i found is that the plug was never plugged back in after my Dad and I pulled the dash wiring harness. Can anyone very accuratly describe or photograph the location of the turn signal/ hazard unit for me? All the FSM says is that it is inside the insturment cluster. POS book... Quote Link to comment Share on other sites More sharing options...
ShawnW Posted September 24, 2003 Share Posted September 24, 2003 are you asking what color the wire plugs from the switch are or what color the plugs that go to the switch are? The ones from the column are wrapped in a tan wire sheating and its a white plug and a brown plug. Shawn Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted September 24, 2003 Author Share Posted September 24, 2003 there is a black 4 plug connecter housing 3 wires that connects to the turn signal/ hazard unit. i need to know where the unit is so i can plug this connecter back in! Quote Link to comment Share on other sites More sharing options...
ShawnW Posted September 24, 2003 Share Posted September 24, 2003 The unit is black and is at the very top of the column directly next to the steering wheel as you would guess by looking at it without the covers off. Would taking the colored plastic off the column help you figure this out? 7-8 phillips screws and you would be able to see the whole workings within the steering column. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 24, 2003 Share Posted September 24, 2003 I think he's refering to the flasher unit - the part that actually does the flashing. Not the switch in the column. I don't know where it is exactly.... GD Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted September 24, 2003 Author Share Posted September 24, 2003 GD you hit the nail on the head! im looking for the flasher unit!!! please help me!!! Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted September 25, 2003 Author Share Posted September 25, 2003 bump Quote Link to comment Share on other sites More sharing options...
thealleyboy Posted September 25, 2003 Share Posted September 25, 2003 Freaker, You said that something was unplugged, and that's what's preventing your lights from flashing. Maybe, but a burnt bulb would give you the exact same symptoms. I'd check those out first before assuming the flasher circuit. If your turn signal indicator comes on at all when you hit your turn signal, you can pretty much rule out a loose connector. One way to test the flasher unit module by turning on the hazard lights. This circuit is independent of the turn signals. good luck, John Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted September 25, 2003 Author Share Posted September 25, 2003 Nope, Im 100% sure the flasher unit is unplugged. when i hit the turn signals or the hazards nothing happens in the dash or outside the car. besides i looked in the FSM for what the wires looked like and the plug i am looking at is the one for the flasher unit. where is the flasher unit?!?!?! Quote Link to comment Share on other sites More sharing options...
ShawnW Posted September 25, 2003 Share Posted September 25, 2003 786111030 is the part number. I cant seem to find a diagram that shows where it is in any of my parts manuals. The diagram indicates its slightly to the left of the center of the car under the dash but its very vague. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted September 26, 2003 Author Share Posted September 26, 2003 went and looked at my carb'd parts car and i found the SOB. i think my hand is permantly deformed now though!!! Quote Link to comment Share on other sites More sharing options...
85glwagon Posted February 1, 2005 Share Posted February 1, 2005 lol, tell me about it, i just replaced the damn thing just to find out that wasn't the problem Quote Link to comment Share on other sites More sharing options...
MilesFox Posted February 1, 2005 Share Posted February 1, 2005 the hazards are on the hazard/horn/clock fuse do the lights come on ut not flash? Quote Link to comment Share on other sites More sharing options...
ShawnW Posted February 2, 2005 Share Posted February 2, 2005 Exactly what Fox is saying, if your clock reads 1:00 every time you start the car COLD then the problem is the whole circuit not just the flasher unit. Quote Link to comment Share on other sites More sharing options...
TheYeti Posted December 6, 2006 Share Posted December 6, 2006 Sorry to bump this old thread, but does anyone know where in the heck this stupid thing is actually located? I need to replace mine and cannot find it anywhere. Manual says it is near the fuse box, but I don't see it there. Quote Link to comment Share on other sites More sharing options...
TheYeti Posted December 11, 2006 Share Posted December 11, 2006 I found the hazard flasher unit... finally. What a pain, but at least it is fixed Quote Link to comment Share on other sites More sharing options...
