Guest moosens Posted July 30, 2003 Share Posted July 30, 2003 You think I'd know this by now....thanks for any help. Quote Link to comment Share on other sites More sharing options...
Guest GeneralDisorder Posted July 30, 2003 Share Posted July 30, 2003 Seems like it could be made to work. I don't see why not. The only thing I would make sure of is that the feedback carb specs are the same - unless the EA81 carb doesn't have the feedback stuff on it, but then your ECU light on the dash will come on for sure, since the system has no carb to control. Not sure about the manifold - but you could always use an EA81 manifold as well. I know the weber has to be turned around to not interfere with the disty - that might be an issue as well. I don't know how much difference in size there is between EA81 / EA82 hitachi carbs. GD Quote Link to comment Share on other sites More sharing options...
Guest McBrat Posted July 30, 2003 Share Posted July 30, 2003 I think the carb mounting holes are different, so you would need the intake as well... Quote Link to comment Share on other sites More sharing options...
Guest OH Noah Posted July 31, 2003 Share Posted July 31, 2003 Carb mounting holes are different, and the EA81 carb is smaller. The EA81 carb is a 26/30 while the EA82 carb is a 28/32. Quote Link to comment Share on other sites More sharing options...
Guest moosens Posted July 31, 2003 Share Posted July 31, 2003 Thanks guys. Quote Link to comment Share on other sites More sharing options...
