Electric door locks
8 replies to this topic
#1 e3mt
e3mt
    USMB Regular
  • PipPipPip
  • 100 posts
  • Tennessee
Posted 24 September 2003 - 12:12 PM
Have electric locks on my 94 Legacy. Lately it has been hit-or-miss with the passenger doors locking or unlocking when I use the driver side lock to activate them.
Some pass locks will open, some will not, and some will, but very slowly.
Any ideas? thanks - mt
#2 e3mt
e3mt
    USMB Regular
  • PipPipPip
  • 100 posts
  • Tennessee
Posted 26 September 2003 - 10:02 PM
Anyone?
#3 davidv
davidv
    New User
  • PipPip
  • 17 posts
  • nederland
Posted 11 September 2004 - 03:18 PM
Having similar situation with my newly purchased 91 legacy...you're not alone on the need for fix-it help.
#4 SevenSisters
SevenSisters
    Subaru Nut
  • 512 posts
  • Cleve/Akron Ohio
Posted 11 September 2004 - 08:48 PM
Most sporadic problems with electric door locks are due to the wires from the drivers side contol breaking due to flexing every time the door is opened and closed. You need to do some wire tracing.
Good luck.
#5 jcniest5
jcniest5
    Eat, Live, Breath Subaru
  • 343 posts
  • The Twin Cities
Posted 11 September 2004 - 10:36 PM
I'm in the same boat with you. Sometimes the door (especially the driver door)will lock itself and if I don't have the key with me, I'm locked out. Sometimes when an open is attempted to open the front passenger door, the handle will trigger the lever to lock itself and unless there is a person inside to hold the lever mechanism, you can't open the door at all. I never bother to do anything about it knowing it's getting old.
#6 djmark7
djmark7
    USMB is life!
  • 278 posts
  • NW New Jersey
Posted 12 September 2004 - 02:51 AM
same problem here, i think it might have something to do with weak or broken springs in the internal lock mechanism in the door i tried getting it off but i couldnt thats the only thing i can think of
#7 canajun2eh
canajun2eh
    USMB is life!
  • 222 posts
  • Ottawa, ON, Canada
Posted 12 September 2004 - 05:46 AM
Sounds like the linkages in all the doors need lubrication, and possibly some adjustment (especially the driver's door).
Remember that the driver's door lock works a switch located where the actuator is found on the other doors. If the linkage is set too short or if the switch is loose, the switch won't operate reliably. If the linkage is too long, the switch might operate accidentally when you close the door, especially if you slam it.
The actuators in the other doors are very low-power electric motors. If the linkages are stiff due to lack of lubrication, the motors won't be able to operate the locks.
#8 rweddy
rweddy
    1000+ Super USER!
  • 1,408 posts
  • Castle Rock, CO
Posted 12 September 2004 - 07:49 AM
I had the same issue with my 96.
Check out this thread
I was able to fix the issue on my wagon.
#9 kmix99
kmix99
    USMB Regular
  • PipPipPip
  • 76 posts
  • williamsport pa
Posted 20 August 2005 - 08:26 PM
I know this thread is old but it was very useful in solving my 1992 legacy door lock problem. My locks would work hit and miss---seemed better in the cold weather.
I will only add that my 92 door lock assembly in the driver's side door looks a little different than the 95's and up. The part you want to take apart and clean is the black rectangular piece where the larger of the 2 electrical connectors attaches -- it has a black accordion-like boot with a plunger arm. Once you remove this switch from the assembly, remove its cover which is held in place with 4-5 small screws. Once open, you will see 4 copper sliding contacts that activate when the plunger moves in and out. Mine were very dirty and black. I cleaned everything with rubbing alcohol & an ink-pen eraser. I also bent the the contact arms down a little so there would be a better connection/ more tension. Use di-electric grease as lube and re-assemble. Solved my problem--- I'm so happy they work again!
