Guest rabin Posted July 23, 2003 Share Posted July 23, 2003 Hi all, I am trying to replace the A/C belt tensioner with a new part - local dealer says they can't find it. They called Subaru Canada and they don't list it either. This is the tensioner that bolts to the alt bottom bracket, has a nut at the pivot point with a bolt that goes through it to the bracket. Loosen bolt, use nut to tension the A/C belt, then lock down bolt - that thing I don't think that's right so I thought I'd ask here if anyone has the part number or knows how to get it. I tried the wreckers, but have not found a smooth turning one and I'm tired of looking. Thanks much! Quote Link to comment Share on other sites More sharing options...
Guest EmmCeeBee Posted July 23, 2003 Share Posted July 23, 2003 Don't know if this is it exactly, but they list idler pulleys under "Cooling -> Belts and Pulleys" here: http://www.carparts.com I haven't used them to order parts, YMMV. Hope this helps. -- Mark Quote Link to comment Share on other sites More sharing options...
Guest 5280wagon Posted July 24, 2003 Share Posted July 24, 2003 rabin you can replace just the bearing. much cheaper. dealership charged me $14, and it's easy to swap out. marco Quote Link to comment Share on other sites More sharing options...
Guest electryc monk Posted July 31, 2003 Share Posted July 31, 2003 We just re tapped the unit for a piecew of standard threadd rod and then used two nuts and two washers for braising at the top of the threaded rod and then it worked for me. Quote Link to comment Share on other sites More sharing options...
Guest Dennis Posted July 31, 2003 Share Posted July 31, 2003 i think i have a good one if you are interested... the car will run fine without the idler/tensioner in place, the compressor just wont run because itll slip with one belt on it... Quote Link to comment Share on other sites More sharing options...
Guest OH Noah Posted July 31, 2003 Share Posted July 31, 2003 You can get a new bearing for it at NAPA. I think I even got mine at a cheaper parts store. The bearing was held in place by a spring clip, and was pretty easy to replace. I believe I paid $10-$12 for it. Quote Link to comment Share on other sites More sharing options...
