My EJ22 Chronicle Update(10/2) PIX(10/2)
13 replies to this topic
#1 tailgatewagon
tailgatewagon
    1000+ Super USER!
  • 1,058 posts
  • Bozeman, MT
Posted 29 September 2005 - 12:04 AM
Reciver car 1979 GL wagon 4x4 ea71.
doner car 1994 LEG LS 4dr sedan. awd 5speed.
progress made.
1994 legacy
wiring harness pulled from Legacy. took 4.5 hours but i have headlights to taillights....and everything in bettween. im going to take pix of everything hopefully it will help others. anyway pix to follow tomorrow.....
motor ready to pull (2 bolts holding it in.)
1979GL.
engine compartment paint came today.... lost of NOS parts ready to go on.
i figured i would start a tread about it instead of posting a new thread every other day with progress..
#2 wesley willis
wesley willis
    Eat, Live, Breath Subaru
  • 278 posts
  • port alberni, bc, canada
Posted 30 September 2005 - 02:19 PM
best of luck. if i had the money/time/mechanical inclination for such a project i would do the same thing to my hatchback.
#3 tailgatewagon
tailgatewagon
    1000+ Super USER!
  • 1,058 posts
  • Bozeman, MT
Posted 03 October 2005 - 12:58 AM
UPDATE,
ea71 is out along with trany!!!!!!!!!!
test Fit EJ22.......
had to widen motor mount holes 1/2 in each side. fits like a glove.... kinda cool the distance between the motormount bolts and the center of the front axle is within 1/8 in between 1979 1600 sr, and 1994 ej22 5speed.....
http://www.ultimates...=500&ppuser=679
pix here...
also working on wiriering harness looks to be about 15% done on that:rolleyes:
#4 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 03 October 2005 - 01:10 AM
VERY nice, I didnt know the motor mounts were so close to being the same...
Got any pics from under the mount so we can see the bolt holes?
Oh, and what tranny will you use?
#5 tailgatewagon
tailgatewagon
    1000+ Super USER!
  • 1,058 posts
  • Bozeman, MT
Posted 03 October 2005 - 09:19 AM
going with the legacy trany. WILL not be an OFFRoader. but more of a rally car consept.
and since rx tranys dont grow on trees.....
no pix from under the crossmemeber just the ones that show. the mount will post more pix of that next time i work on the car.....
#6 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 03 October 2005 - 05:39 PM
What will you have to do to get the legacy tranny to fit? Different axles? custom length driveshaft?
Im very curious about the details...
#7 tailgatewagon
tailgatewagon
    1000+ Super USER!
  • 1,058 posts
  • Bozeman, MT
Posted 04 October 2005 - 12:29 AM
size wise it should fit fairly well.
as for axels i will just run the normal gen 1 axels with ea82t inner cups. that will allow me to mate them to the legacy trany(25 spline just like ea82t tranys) the stock non turbo pre legacy tranys were 23 spline....
i will have to mod the trany crossmemeber a bit as the leg trany is longer then the sr ea71 trany. ill see what kind of mods need to be done when i get there. as i have a lift to use. i will install the motor first then the trany as to get the fitment right. then ill make my pitching stopper and what not
#8 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 04 October 2005 - 05:07 PM
Sounds good...
Are you going to try to pass smog with it?
#9 tailgatewagon
tailgatewagon
    1000+ Super USER!
  • 1,058 posts
  • Bozeman, MT
Posted 05 October 2005 - 12:13 AM
heck no i will never live where i have to smog a car
#10 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 05 October 2005 - 12:43 AM
Ya, its pissing me off, mine is grounded indefinatly at the moment due to smog... I'm thinking swap now cause of it, and cause of the access to people who can actually do swaps in this area. Money of course is the main issue...
#11 bajavwnsoobnut
bajavwnsoobnut
    Insane Rally Freak
  • 3,789 posts
  • Milwaukie
Posted 09 October 2005 - 02:28 PM
Awesome man so you could basicaly use a sledge to modify the frame rails just enough to get access to the valve covers and plug wires (DOHC EJ's) and have fun with more power without having to mod the crap out of it
#12 rguyver
rguyver
    USMB is life!
  • 218 posts
  • Kelowna B.C. Canada
Posted 11 October 2005 - 01:03 PM
[quote name='as for axels i will just run the normal gen 1 axels with ea82t inner cups. that will allow me to mate them to the legacy trany(25 spline just like ea82t tranys) the stock non turbo pre legacy tranys were 23 spline....']
So you dont have a headake when you get to it , the EA81 \ gen 1 axels wont except the later EA82t inner cups unless you respline the shaft at one end .
#13 bajavwnsoobnut
bajavwnsoobnut
    Insane Rally Freak
  • 3,789 posts
  • Milwaukie
Posted 11 October 2005 - 03:40 PM
well then I wonder what ones would work with gen 1 vehicles for shafts then
#14 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 15 October 2005 - 04:43 PM
Any updates???
