head gasket on an EA-81
4 replies to this topic
#1 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 26 September 2003 - 01:51 AM
how often do these blow? I don't think its a coolant leak but the gasket looks soaked with oil. what could this be? I'm also think I'm getting air in the coolant system could this be it?
#2 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 26 September 2003 - 11:51 PM
bump, anybody know anything about this?
#3 TomRhere
TomRhere
    Certified BRAT nut!!!
  • Gold Subscribers
  • 4,467 posts
  • Hillsdale, Mi. USA
Posted 27 September 2003 - 07:37 AM
Can't say as to how often the EA-81's will lose a HG, but any HG is subject to blowing. Are you losing coolant, oil? Have you done a compression test? Bubbles, or oil, in the coolant, is a good sign of bad HG. Also steam out of the exhaust pipe, is a major sign of bad HG. Should see if a local repair shop will do a sniffer test on your coolant system. This will show if you have combustion by-products in there. If so, HG is toast......
#4 Ratty2Austin
Ratty2Austin
    have tools, will fix
  • 2,386 posts
  • West Coast USA
Posted 27 September 2003 - 03:51 PM
EA81 head gaskets dont blow so often, compared to EA82 or EJ25... but they still can go! other possibilities could be cracked heads, or block... not likely, but possible...
luckly, they are easy to change :D
2 indicators that are very obvious that will tell you if you have a blown headgasket
-bubbles in the antifreeze (with car running, before it warms up)
-water (brown foam) in the oil
good luck!
#5 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 28 September 2003 - 01:38 AM
I have bubbles in my rad. I will try and do a comp. test soon
