I need to buy yet another used Subaru... :clap:
I own a PAIR of 1988 Subaru GL wagons, 4x4, with dual range 5-speed, and SPFI on the 1.8 engines. I LOVE these cars!!!! I travel a REALLY steep hill to get home (in West Virginia)---that low range tranny is great in the winter!
I'd like to move into a slightly newer (lower mileage) Subaru.... but I'm totally unfamiliar with what's available from 1990 on thru the mid 90's. I think I've heard there are some models that are best avoided.
I'd be interested hearing if there are 5 speeds with lower-than-usual first gears (I just KNOW I'm going to miss that dual range box!)
Would appreciate hearing about general reliablilty, rust issues (shudder), and other opinions. :wave:
EJ20 and EJ22 engines are very good. EJ25 has cylinder walls too thin to keep head gaskets tight, so are best avoided. The gaskets have been through a number of redesigns, likewise the block and head, not sure if it helped.
Early 1989-mid 1990 5MT boxes are bad - main bearings die at 120K miles. Clutch swaps between 2000 and 2003 could mean cold judder - GM to thank for that one.
Legacies are 70% galvanised so rust doesn't run rampant. Not sure what percentage on the Impreza, but likely to be similar. Check the bottom rear of the passenger door frames. Rust loves to start at the point where its welded to the sill.
Wheel bearings have a reputation for going easily, but I am only now beginning to hear one of my fail, at 185k miles.
Yeah, I've been kinda dreaming about a used Sube for myself (we are new to Subaru and the '03 H6 OBW is really my wife's though I'll probably end up putting 1/2 it's mileage on it - hey, how do folks accustomed to metric refer to 'mileage' on cars?) adn wonder about the '96 and up YMs. W.Virginia probably doesn't get a s hot as Texas but I was told the R-134a wasn't used in Subes before '96 or so. That would be a concern for me.
So what engines are in '96 and up?
Carl
1 Lucky Texan
I really liked the 2.2 engine and my brother in law in New Zealand has had great luck with them as rentals in Queenstown.
The 2.5 has been a bit of a disaster for Subaru's reputation. I only ended up with one myself because I wanted a Forester and they only came with 2.5s.
If you can rent a car to a skier and get it back in one piece it is tough.
By the way did you know that a ski rack is the most potent performance accessory?
Ever have to pass a car with a ski rack?
From what I've read here, everyone seems to agree that the 2.2 L engine is a very good engine. In pre-1995 cars the 2.2 was available in both the Impreza and the Legacy. What are the strengths and weaknesses of these two models?
ONE feature I would be most interested in is the ability to proceed down a very steep hill as slowly as possible. I travel a good bit of gravel road---which sometimes gets a bit rutted. My '88 GL 4WD wagons handled both of these situations nicely. In 91-95 do I have a choice between AWD and 4WD? Opinions?
The Legacy came first. Colin McRae raced one in the WRC early 1990'ies. To make it more agile they decided to cut the wheelbase down, and hey presto created the Impreza! Therefore the mechanicals are pretty much identical.
I would recommend a Legacy since it has slighty softer springs which would do well on the rough. The longer wheelbase might also aid stability on the steep slopes.
There is a hi/lo transfer case version of the manual, but I have no idea where and when it was produced. Even so, first gear in the 5MT is quite low/short.
ABS is also more likely on the Legacies, and I expect that would be helpful on a steep muddy slope??
My 96 Legacy has ABS and a 2.2 l engine. (AWD was optional, and I have it.) I love this car! Sometimes I miss my 86 GL d/r, but overall I really like my Legacy. Haven't had any problems dealing with snow. Not tried driving down any steep hills. 105K, with just the average repairs (except for a disaster with an independent mechanic!).
same here, 96 legacy with ABS & the 2.2l. 100k miles since new.
Very reliable, never left me stranded (except for the OEM battery, whch died after 7 years !)
not very fast or sexy, but it just works, day in and day out.
repairs have been minor, a camshaft angle sensor, new shocks/tires, and now the driver's side window switch is starting to stick. But that's been it.
One of the cars "I'm looking at..." is a 1995 Impreza Outback Wagon---with the EJ18 engine, 5 speed manual, AWD, and A/C.
I like the way it looks... but I figure it's a tad underpowered. I'm kinda used to driving my '88 GL with the 1.8 engine---and turning off the A/C on really long uphill grades on interstates. I figure it might be the same deal with that Impreza.
According to the figures I have available, the EA82 SPFI in my '88 puts out 90 HP@5600.
The EJ18 in the '95 Impreza puts out 110 HP @5600----so maybe it wouldn't be too underpowered with that EXTRA 20 HP. Hey, EVERY car I've ever owned has been underpowered.... I LIKE using a gearbox!
Is the EJ18 as long-lived as the EJ22 ?
If I decided to go with a Legacy, I would certainly avoid the EJ25...
There's a used Subaru specialist up in Western MA that swore by the EA81 and EJ22/EJ18 engines to the point that he warrantied all used Soobs he sold with the engines to 100K miles, no deductible, on all drivetrain components. I think he stopped last year (they're getting scarcer in the used market, at least with low mileage) but he's still in business.
Today we're going to look at a 1996 Subaru Legacy Brighton wagon, 2.2L, 5 speed manual AWD. The Brighton lacks power windows and door locks---which I never liked in any car.
Did Subaru do something to the '95 and newer Legacys (other than the 2.5L engine) that I should be aware of?
I see they are a few inches longer, wider, and taller---and a few more horsepower, plus airbags.
yeah the 1 gen legaycs are really nice, and cheaper. My dad has 330,000 miles on his 90 legacy 5spd awd, and my mom has 190,000 on a auto wagon awd. These cars can take a beaton and keep runing to. I bought one(90 legacy 5spd awd) at a aution for $100 to beat on it. It never broke, after jumps, mud, and rocks, it had 227,000 on it to. The cars 1 gear is low enogh to go off road to a extent, but i had to slip the clutch alot to get it out of some deeper sand. I eneded up selling it as a winter beater to my cousin.
