Alternator voltage in my 92 loyale
7 replies to this topic
#1 PennyMc
PennyMc
    New User
  • PipPip
  • 14 posts
  • Vancouver Island
Posted 10 October 2005 - 02:55 PM
my voltage spikes to about 17volts at about 4000rpm and up- is this normal?
#2 hatchsub
hatchsub
    Currently Subaru-less :(
  • 2,714 posts
  • Guilford
Posted 10 October 2005 - 03:02 PM
It shouldn't be doing that. That means the alternator is overcharging which is not a good situation. You should get it replaced or if your not sure it needs to be, have a mechanic hook up a tester to it and make sure the gauge is reading correctly.
#3 PennyMc
PennyMc
    New User
  • PipPip
  • 14 posts
  • Vancouver Island
Posted 10 October 2005 - 03:04 PM
We used a mulit-meter and it is correct...the voltage goes up high when the rpm does....so it may not be as simple as a loose wire or something stupid like that?? Thank you
#4 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 10 October 2005 - 03:05 PM
well does it run like crap when its at 17 volts? if not, I wouldnt worry about it. If everything runs fine, your gauge might be messed up. Easy way to test it is get a voltmeter and put it on the charge wire comin off the alt. single wire with the ring on it I believe. hopefully somone will jump in to confirm
If it does start dogging down u need a new voltage regulator (alternator) because they are internal regulators
#5 TROGDOR!
TROGDOR!
    Pastor of Muppets
  • 2,106 posts
  • Morgantown, WV
Posted 10 October 2005 - 03:14 PM
This is a common problem. The voltage regulator has died. It's internally regulated, so you need to replace the alternator. This WILL damage your electronics if you leave it alone.
#6 squatty
squatty
    New User
  • PipPipPip
  • 31 posts
  • Portland
Posted 10 October 2005 - 03:55 PM
Penny - Funny you should post this! I have been watching the voltmeter on my 92 Loyale as the same thing is happening to me!
On a 500 or so mile round trip last week I noticed my voltage getting up that high also. I wasn't sure it was a new occurence but believe it used to run around 15 or so.
#7 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 10 October 2005 - 04:05 PM
Even 15 is high on the gauge. Mine...when it was running (currently has another crappy alternator) would be just about 12.5 volts.
#8 PennyMc
PennyMc
    New User
  • PipPip
  • 14 posts
  • Vancouver Island
Posted 10 October 2005 - 04:58 PM
Well I've already replaced the battery and put 2 new head lights in because of this problem....so off to the store to get a new alternator.....at the rate I'm going with repairs I'm going to have a brand new car by the end of the week...lol. as usual, thanks for all your help guys!!
