passing emissions with a weber?
13 replies to this topic
#1 hatchsub
hatchsub
    Currently Subaru-less :(
  • 2,714 posts
  • Guilford
Posted 13 October 2005 - 04:42 PM
Will my car pass emissions if i put a weber on it and get rid of all the stupid mess under the hood? Im kinda getting sick of this one barrel carter carb but not of its milage (27 to the gallon). Any ideas? I just want to keep this car legal. Its an 83 EA-81 just for clarification.
#2 nipper
nipper
    Semi Elite Master of the
  • 18,191 posts
  • Long Island NY
Posted 13 October 2005 - 06:28 PM
Your in Ct ? Do you have ther state doing your emission testing, or do private garages do it ?
Also if the car your talking about has less then 100K on it, they may not pass you.
All that crap is also helping you get good gas milage. Why do you want to change it?
nipper
#3 HooptyGL
HooptyGL
    Banned
  • Banned
  • 174 posts
  • Prescott
Posted 13 October 2005 - 07:02 PM
nipper
CT had the emissions banned in the state for over a year because there was no state regulation done to ensure that the third party testers (private garages) wern't letting people pass when they shouldn't. as far as i know the emissions have been re-instated in the state and are far more rigorous. Im pretty positive that if you have a single barel weber on your ea81 you wont pass.
Once i installed my double barrel weber on my ea82 my mileage went up to over 30 mpg highway....but i recently backed into a huge stump in my driveway and now my pipes are basically f'd=crappy around town mileage....but tomorrow the car is getting new ones from the headers all the way back minus any cat(s).:brow:
#4 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 13 October 2005 - 07:22 PM
nipper
I replaced the single barrel carter-weber on my son's '82 brat recently with a 32/36 weber. Highway gas mileage went from 20-21 to 27-28 with that change. I'd think the emissions went down from previous since more gas was going into making the car move more efficiently; I did pass WA state emissions after making the switch also; I don't know how you would fare in CT.
#5 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 13 October 2005 - 07:56 PM
"Once i installed my double barrel weber on my ea82 my mileage went up to over 30 mpg highway....but i recently backed into a huge stump in my driveway and now my pipes are basically f'd=crappy around town mileage....but tomorrow the car is getting new ones from the headers all the way back minus any cat(s).:brow:[/QUOTE]
The emissions test have started up again. My subaru has already passed..on its second try. It needed a new O2 sensor. The reason i want to change the carb is to get a bit more pep out of it and get rid of the hessitation. Ive been told by a fellow that has worked on these since they were new that the carter weber carb was the worst they put on these cars and that mine is running as good as any he has seen but it still hessitates when it is cold.
#6 nipper
nipper
  • 18,191 posts
  • Long Island NY
Posted 13 October 2005 - 08:09 PM
As long as you can pass emissions go for it. The cat is pretty good at making up for a majority of sins :). As long as they dont pop the hood to make sure everything is still connected.
nipper
#7 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 13 October 2005 - 08:15 PM
Will the O2 sensor still function with the weber or will i be getting rid of that too?
#8 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 13 October 2005 - 09:07 PM
I left the O2 sensor hanging; there's nothing on the weber that will respond to it, but I didn't want to plug the hole by removing it. I just tied up the wire from it so it didn't get ripped up in something.
#9 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 14 November 2005 - 11:14 AM
I know this is an old post of mine but i have a few more questions about the weber. Will it set off any trouble codes in the computer because im not running the O2 sensor? What did all of you people do with all the vacuum line mess when hooking it up? I mean the EGR valve and the reed valves on either side that are hooked to the header with a steel pipe? Thanks again!
#10 Subarian
Subarian
    1000+ Super USER!
  • 1,150 posts
  • Orem
Posted 14 November 2005 - 12:06 PM
The 32/36 doesn't need an O2 sensor, but you can use it to set up the jets in the Weber. If it's set up right, it will pass emissions easily, and you'll get more power and economy, too.
Most of the vac lines can be blocked. The EGR isn't doing you any favors, so you can block that, too. The AIR lines that go to the exhaust port can be blocked off, too. I just sawed mine off flush and put a nickel under each one to block it off.
The main thing to watch for is anything that's required for a visual emissions inspection. For example, in Utah, the car has to have all the original emissions equipment to pass the visual inspection before it even goes on the dyno. So the EGR is still there, it's just blocked off. The vac lines are still there, but the ones that aren't needed are blocked internally.
#11 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 14 November 2005 - 12:22 PM
Im not sure i understand the nickel to the air tubes? Can u explain that a bit more for me?
#12 Subarian
Subarian
    1000+ Super USER!
  • 1,150 posts
  • Orem
Posted 14 November 2005 - 12:53 PM
I just cut off the tube from the flange. Then I put a nickel (it may have been a quarter, I'm not sure) under the flange to seal it off. Surprisingly, it hasn't leaked in almost 100,000 miles.
#13 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 14 November 2005 - 02:11 PM
Anyone ever find a bolt with the same threads and just bolt it in at the header?
Also anyone ever have any problems with a weber icing over in the winter?
#14 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 14 November 2005 - 03:53 PM
really debating the weber now. Anyone know where i can get a set of gaskets to mount it to the intake? I cant seem to get through to anyone at redline...EVER!
