heater fan wont blow on high
No, there isn't a seperate fuse for the high setting though after looking at my manual for an '88 model it shows fuses 1 and 2 supply power to the circuit (I never noticed that before). The print shows that the switch makes a ground connection to run the motor so you should be able to just ground the high switch position to check the switch and the motor. If that doesn't work, then the wire to the motor has a bad connection somewhere.
thanks glen,it worked only a few days ago,so im not sure whats going on.is there a fuse for high fan? ed
