duty solenoid c?
9 replies to this topic
#1 monstaru
monstaru
    bought AND built?
  • 4,161 posts
  • OlyWa
Posted 18 October 2005 - 04:31 PM
does anyone know if these are replacable and if they are the cheapest place for quality product........this is on a 92 legacy ls wagon 4 speed at tranny. thanks, brian
#2 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus
  • 3,813 posts
  • Texas
Posted 18 October 2005 - 04:57 PM
You might ask Jamie at www.subarugenuineparts.com about the price and availability.
I'd be interested in knowing how you determined that part is bad.
#3 Subie Gal
Subie Gal
    GC84Ever
  • 1,354 posts
  • WA
Posted 18 October 2005 - 06:13 PM
To view pricing, or to order the duty solenoid you have requested:
1) you will need to use our OEM catalog. see: https://www.subaruge..._parts_cat.html
2) order by part number 16102AA013
Let me know if you have questions :)
Jamie
#4 All_talk
All_talk
    1000+ Super USER!
  • 1,093 posts
  • Thorp (Ellensburg)
Posted 18 October 2005 - 07:37 PM
Just to add some more info, here's a pic of its location with the tail housing removed... its the bit with the wire attached.
Posted Image
Gary
#5 leadfootracin
leadfootracin
    USMB Regular
  • PipPipPip
  • 66 posts
  • seattle
Posted 18 October 2005 - 11:25 PM
did the sol ohm test bad? I had a legacey wgn that all codes said duty sol c was bad, car had torque bind, fuse in didnt help, pinned out trans ecu, trans ecu was bad.
#6 monstaru
monstaru
    bought AND built?
  • 4,161 posts
  • OlyWa
Posted 19 October 2005 - 12:54 PM
i just took the codes..........whether or not that is actually the problem remains to be seen.especially now that the engineer got involved and is showing me that it is inside the case.:lol: your an f-in rock star , i love you man....
thanks, for the link jamie.......
#7 All_talk
All_talk
    1000+ Super USER!
  • 1,093 posts
Posted 19 October 2005 - 10:10 PM
Who’s the rock star??
I’m sure you could ohm test the C-solenoid at the connector on the top of the trans, I don’t know which wire it is but I bet somebody does, if not I could do a little checkin on the old 4EAT I have in the shop.
Here are a bunch more pics inside the 4EAT.
http://photobucket.c...lk/Subaru/4EAT/
[font="][font=Verdana]
I didn’t get into rebuilding the clutch packs and such. I was just swaping my 3.9:1 diff on to it (replacing the 4:11) so I could use it in my ’92 Turbo Legacy. I did swap the C-solenoid from my old trans cause the PO thought it might have had a problem, I’m not sure that was the problem. I found that the clip that holds the pressure pipe feeding the transfer clutch wasn’t holding the pipe in firmly and it may have been bleeding off pressure. You can see the clamp and pipe in this pic.
[/font]
[/font][font=Verdana][font="][font=Verdana]
http://photobucket.c...nt=Image008.jpg
Gary
[/font] [/font]
[/font]
#8 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 5,595 posts
  • Virginia
Posted 21 October 2005 - 10:43 AM
i have the same problem in my 97 obw. i was planning on swaping out the clutch pack, but need to check the ecu/tcm (? i don't the difference or which one to check.) where is the unit located, in the car or on the trans. can i swap one out of another 97 obw to check it. are the units expensive? new or used?
i don't really want to pull the trans.
thanks, john
#9 leadfootracin
leadfootracin
    USMB Regular
  • PipPipPip
  • 66 posts
  • seattle
Posted 21 October 2005 - 06:37 PM
on the 91 legacy wgn the trans ecu was under the left side of the dash. its been awhile but i seem to remember that the trans ecu was supossed to supply voltage to the duty c sol to hold it in 2 wd. I think i found the pinouts somewhere on these boards. good luck jr
#10 leadfootracin
leadfootracin
    USMB Regular
  • PipPipPip
  • 66 posts
  • seattle
Posted 21 October 2005 - 11:37 PM
a clue http://www.ultimates...php/t-9847.html
