Cant leave 4WD!!!!!!! HELP
9 replies to this topic
#1 BlindSight
BlindSight
    Subaru Nut
  • 653 posts
  • Denton
Posted 19 October 2005 - 03:29 PM
So figured it was time I tested out my 4wd for the first time so I start my wagon, shift it into 4wd high and head for the paintball field, had a great time, everything worked awesome, go to taco bell, stop, and try to shift back into FWD, wont budge, my wheels are straight and everything seems like it should work.....but have tried for about an hour now and cant seem to get it back into FWD. CAN ANYONE HELP ME????????? SUGGESTIONS???
#2 Bobby_boucher
Bobby_boucher
    Eat, Live, Breath Subaru
  • 319 posts
  • Grandview
Posted 19 October 2005 - 03:32 PM
have you tried slowly rolling forward and gently pushing it down? or slowly backward and doing the same?
#3 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
1 - don't use 4wd on dry pavement
2 - put it in reverse and back up until drivetrain load is lessened
#4 75subie
75subie
    I`m sold on Subaru
  • 3,910 posts
  • Walden
Posted 19 October 2005 - 04:10 PM
do the above, if it doesn`t go out easilly, come down like a pile of bricks on it.my subes always do that when in 4wd on dry pavement.
#5 zyewdall
zyewdall
    Subaru Master
  • 2,136 posts
  • Ward, CO
Posted 19 October 2005 - 04:49 PM
Jack up one wheel -- should free up any tensions in the drivetrain and it will go right into 2wd unless there's something binding up in the actual levers.
#6 northguy
northguy
    O.C.A.L. Life Member
  • 4,352 posts
  • Chugiak, AK
Posted 19 October 2005 - 05:04 PM
Or drive onto the lawn or some gravel and then shift out. (Don't feel bad, I did the same thing the first time I shifted into 4wd).
#7 BlindSight
BlindSight
    Subaru Nut
  • 653 posts
  • Denton
Posted 19 October 2005 - 05:58 PM
jacked it up and it shifted out, THANKS SO MUCH FOR THE FAST HELP!!!! YOU GUYS ROCK!!!!!!!!
#8 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 19 October 2005 - 06:01 PM
Next time remember to shift out while you are still on a slippery surface :)
#9 BlindSight
BlindSight
    Subaru Nut
  • 653 posts
  • Denton
Posted 19 October 2005 - 06:27 PM
thanks, had a blast even though my tires are almost bald and everything is stock...still handled some big crevacise and pot holes like a champ.
#10 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,120 posts
  • Oregon City
Posted 19 October 2005 - 08:31 PM
even if you do end up using it on dry pavement again, make sure to drive about 200 feet in a straight line and it'll pop out like it did when you popped it into 4wd.
