MT front seal?
8 replies to this topic
#1 soobscript
soobscript
    needs more time
  • 705 posts
  • Columbus, OH
Posted 19 October 2005 - 08:37 PM
I have my engine out. Lots of gunk in tranny bellhousing area. Is there a seal behind the plate with 4 or 5 bolts behind the clutch fork? Is it a simple to replace? (Like take out bolts, remove old seal, insert new seal, torque bolts.) I don't suspect a leak, but would like to take care of it while it's convenient. I didn't find anything about it in the Haynes book
#2 soobscript
soobscript
    needs more time
  • 705 posts
  • Columbus, OH
Posted 20 October 2005 - 02:25 PM
bump
#3 soobscript
soobscript
    needs more time
  • 705 posts
  • Columbus, OH
Posted 21 October 2005 - 01:58 AM
Is there a seal?
#4 86subaru
86subaru
    Elite Master of the Subaru
  • 3,097 posts
  • ohio
Posted 21 October 2005 - 05:36 AM
there is a rear main seal ,
#5 1984subaru
1984subaru
    USMB Regular
  • PipPipPip
  • 40 posts
  • Perth australia
Posted 22 October 2005 - 10:23 AM
U will have two seals on is the Rear Main seal which is placed around the crank behind the clutch, and a seal place inside the snout of the gearbox (snout is where the clutch bearing runs). Most probally it will be your rear main seal... But u will have to look more at the seals and I would do both while u r there.
#6 soobscript
soobscript
    needs more time
  • 705 posts
  • Columbus, OH
Posted 22 October 2005 - 12:31 PM
The rear main seal was getting replaced anyway. Have you replaced the snout seal? Is it a bolt off, bolt on deal?
#7 soobscript
soobscript
    needs more time
  • 705 posts
  • Columbus, OH
Posted 22 October 2005 - 03:08 PM
Just skimmed my Haynes and two Chiltons. Only found one mention in the input shaft overhaul section: "oil guide"
Am I just wasting my time? Anybody?
#8 1984subaru
1984subaru
    USMB Regular
  • PipPipPip
  • 40 posts
  • Perth australia
Posted 23 October 2005 - 04:16 AM
yeah it is a bolt on/off. no u r'nt wasting your time coz if it is leaking u will have to pull the motor or box back out.
#9 soobscript
soobscript
    needs more time
  • 705 posts
  • Columbus, OH
Posted 23 October 2005 - 09:48 AM
Thanks. I do not think it's leaking. I just want to take care of it while it's easy to work on.
