U-joint axle info. needed
9 replies to this topic
#1 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 20 October 2005 - 05:47 PM
Hi all! I'm looking for some info on the U-joint rear axle.
1) is the outboard end all 1 pice? (ie: splined stub that the yoke slides onto, or no)
2) is the inboard end of the shaft a male or femail? (ie: are there stubs on the diff., or do the axles slide INTO the diff.)
3) how much can the shaft expand and colapse 1" 2" ect.?
Thanks in advance for the help:)
#2 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 25 October 2005 - 04:15 AM
Soooooo............
Has any one here got U-joint rear axles? Ever had one off?:D
#3 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 3,854 posts
  • Bellingham
Posted 25 October 2005 - 01:39 PM
what car did they come on?
#4 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 25 October 2005 - 02:15 PM
Gen 1 Subaru 4WD's, Datsun 510's, 200sx's and Z-cars, Jag's in the '60's & '70's, '50's & '60's Corvets, ect.:grin:
But here, just the 1st gen 4WD's
#5 captainkettel
captainkettel
    USMB Regular
  • PipPipPip
  • 77 posts
  • Olympic Peninsula
Posted 25 October 2005 - 03:59 PM
I have a 1978 4X4 wagon. The rear drive axles DO have u-joints. Lucky for me I have a spare set. Had to change one out a little while back. They are splined on one end and have a 4 bolt plate on the other end. If you would like I have taken a few photos for you to view. I can send the pictures via email. The splined end has a bolt in the center that holds the splines in place.The splines go into the rear pumpkin and the 4 bolt plate bolts to the rear inside wheel. Really quite an easy fix, although I didn't change the u-joint.
#6 captainkettel
captainkettel
    USMB Regular
  • PipPipPip
  • 77 posts
  • Olympic Peninsula
Posted 25 October 2005 - 04:17 PM
Soobme, sent you a PM with more info! Get back to me if you want photos...Dennis...
#7 tailgatewagon
tailgatewagon
    1000+ Super USER!
  • 1,058 posts
  • Bozeman, MT
Posted 25 October 2005 - 10:18 PM
um i know of a couple of sets. they bolt on the wheel end and on the trany end... the stub shafts are interchangle able from th eparts books ive looked...
#8 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 26 October 2005 - 04:04 AM
Cool! Thanks guys! That's all the info I needed on 'em. Now I know that they will not work for what I have in mind:rolleyes:
#9 bajavwnsoobnut
bajavwnsoobnut
    Insane Rally Freak
  • 3,789 posts
  • Milwaukie
Posted 31 October 2005 - 01:17 AM
soobme do you have a set? if so and want to get rid of them PM me
#10 tailgatewagon
tailgatewagon
    1000+ Super USER!
  • 1,058 posts
  • Bozeman, MT
Posted 01 November 2005 - 09:36 PM
i miss spoke earlyer... the end that gos to the wheel is held on by 4 bolts the other end has one bolt that gos through the center that holds it on its like a yoke hooked on the end of the stub shaft.
