New to board...a couple questions
8 replies to this topic
#1 wileyboy
    New User
  • Pip
  • 1 posts
  • Olympia
Posted 28 September 2003 - 10:51 AM
Hello all,
I'm new to the world of subaru. My wife and I bought a 2000 Legacy wagon in July with 60k. We've been a Volvo family 'til now.
Looking for good sources of info on maintenance and repair:
What is the recommended oil filter for this car? Is there and equivalent to the OEM out there and are there good on-line resources for subaru parts?
We discovered that the washer for the front window isn't working; fuse is o.k. as wipers work, and if I jumper it to the rear washer wiring it works. Does anyone know if there is a relay involved in this?
Thanks for your time and knowledge.
Josh Morse
#2 Nug
    Lurker/off-topic poster
  • 1,968 posts
  • West Point, VA
Posted 29 September 2003 - 10:24 AM
It's a little bumpy out here.
#3 mattocs
    Subaru Legacy Lover
  • 1,312 posts
  • Pittsburgh
Posted 29 September 2003 - 10:37 AM
The Subaru oil filter is just a Purolator, or at least they are for my 1995 Legacy. They are a few dollars at the auto part stores.
#4 applegump
    Eat, Live, Breath Subaru
  • 316 posts
  • CH
Posted 29 September 2003 - 02:52 PM
There have been lengthy discussions about oil filters and the general consensus was that the OEM one is the best and they are made by purolator. So either get a purolator or OEM. There are online sources like http://www.subaru-parts-dealer.com/ and http://www.allsubaru.com/ aswell as http://www.libertysubaru.com/en_US/ who sell them cheap, or cheaper than normal dealers. BTW I've only tried Liberty Subaru, I highly recomend them.
For light bulbs and such there is www.midnightmoose.com which is also very good.
Welcome to the world of Subaru :D
#5 theotherskip
  • 329 posts
  • Philly, PA
Posted 29 September 2003 - 05:48 PM
i've had good luck with http://www.1stsubaruparts.com . i got all the parts to replace my head gasket and clutch through them. good service and cheap shipping.
you can also get the factory service manuals for your particular car at http://techinfo.subaru.com .
#6 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus
  • 6,686 posts
  • Texas
Posted 29 September 2003 - 08:15 PM
There are at least 2 'grades' of Purolater filter. The one I got for my OBW had the 'L' in the part number. I think that means it has the ant-drain valve or something. Got mine at Pep Boys and my Mobil 1 at Wally World.
1 Lucky Texan
#7 Commuter
    Subaru Master
  • 1,857 posts
  • Niagara area, Ont Canada
Posted 29 September 2003 - 08:57 PM
If you buy the Purolator filter, there is the "L" which I believe they call Premium, and there is the PureONE filter, which has a "PL" as the start of the number. The PureONE uses synthetic fiber in the filter media and has a greater number of pleats. It filters to lower micron sizes. They can be quite expensive, but if you are interested, ask what 6 or 12 would be. One aftermarket auto shop in our area will sell them for nearly half the price if you take a case of 12.
Based on cutting some open and other peoples detective work, it appears that the Subaru Purolator OEM filter is something akin to the "L" filter. However, I have no way to know what the filter media is made up of. (IIRC, it actually had a few less pleats than the Purolator filter.) I'm almost postivie that it does not contain any of the synthetic filter media... based purely on price.
I'll throw my 2 cents in about filter magnets. They do work. I've cut open about a dozen filters now and there is always something retained by the magnets. One time purchase, totally reusable.
#8 1 Lucky Texan
1 Lucky Texan
  • 6,686 posts
  • Texas
Posted 29 September 2003 - 11:23 PM
Thanx Commuter, I think I got my post backwards. The PureOne filter is what I got.
PL14488 or 89 something like that. Anyway, should be good enough.
1 Lucky Texan
#9 Commuter
    Subaru Master
  • 1,857 posts
Posted 30 September 2003 - 11:53 AM
Purolator 14460 is Subaru specific and fits (all?) H4 engines.
Purolator 14459 is the generic filter (cross references with a whole bunch of other filters) and fits the Subaru H6 engines mostly. I believe the 3.0L H6 and the SVX 3.3L call for this part number. I don't know about the 2.7L engine.
The difference?
The 14460 has a slightly convex base plate to "push out" the threads. Subaru's oil filter 'stud' is on the short side. Filters with the concave base plates don't always catch sufficiently on the threads.
And for the same reason, you can run into problems with aftermarket filters. Ask me how I know. I've been there... :( But I solved it. :-)
The Subaru Purolator OEM filter is a little different again. The guts look to be about the same (as the "L"), but there is no anti-drain back valve. And (IIRC) the gasket was of a semi-round cross section, not square. (I've got this all written down, but I don't have access to it right now.)
