K&N drop in filter
9 replies to this topic
#1 Roostman
Roostman
    New User
  • Pip
  • 6 posts
  • SoCal
Posted 24 October 2005 - 02:22 PM
Hey, just a little heads up/review of a K&N drop in filter for my 03 LL Bean Outback H6. First off, the fit is not as good as stock but with some good 4 letter words it will go in. The lips of the filters seems a little stiff and the cover hard to get back on correctly but like I said, some patience and cuss words will git er done. Now, can I tell a difference for $45? A little bit. Its just a tad more responsive all over but nothing to get excited about. Is it worth the quadruple price tag? Depends on your wallet. I give it a 3 outa 5 rating.
#2 Storydude1
Storydude1
    USMB is life!
  • 167 posts
  • NW AZ
Posted 24 October 2005 - 02:28 PM
They are even better when you find them in the Boneyard, for 3 bucks..:)
I will say the one in my 93 Legacy was a little loose in the airbox. Same results..Not much difference if at all.
#3 swc7916
swc7916
    USMB is life!
  • 159 posts
  • Kirkland
Posted 24 October 2005 - 02:33 PM
The ones in my Outbacks and Baja fit just fine, the one in the WRX is a loose fit. I think that the cars rev a little "freer" at the top end, otherwise I'm not sure if they're that much better. I never kept track of the gas mileage, so I don't have any data to compare that either.
#4 trxeslr66
trxeslr66
    USMB Regular
  • PipPipPip
  • 72 posts
  • ALTOONA
Posted 24 October 2005 - 03:49 PM
I have a Fram AirHog air filter which is the same as a K&N. It fits perfect in a 99 Legacy 2.2, the price was about $5 less than K&N.
#5 Subie Gal
Subie Gal
    GC84Ever
  • 1,354 posts
  • WA
Posted 24 October 2005 - 05:34 PM
after running a K&N on my street car and an OEM on my race car
i have learned....
OEM is much better for the car
BREATHES better and filters better
that oily rag collecting dust and grime isnt helping you much in the long run
OEM for me from now on :)
Jamie
#6 swc7916
swc7916
    USMB is life!
  • 159 posts
  • Kirkland
Posted 25 October 2005 - 10:01 AM
I have an interest in this because I thought that I was doing the right thing by installing K&N filters in all 4 of my cars......
This OEM/K&N debate has been going on for some time and I have yet to see a definitive answer as to whether or not there is a problem with K&N filters. Just by visually comparing the two, it seems obvious (at least to me) that the K&N is less restrictive to airflow than the OEM so should "breathe" better. How is an "oily rag collecting dust and grime" any worse than a dry paper filter collecting dust and grime, as long as it stays in the filter? Isn't that what a filter is for? I suppose that you can't go wrong with OEM, but has anyone documented engine failure or premature wear as a result of running a K&N filter?
#7 Tiny Clark
Tiny Clark
    Certified Subaru Nut
  • 807 posts
  • Germany
Posted 25 October 2005 - 11:24 AM
Under normal circumstances, I don't think you have too much to worry about.
I wouldn't run an oil mesh type filter off-road, I'd use paper. Just my two Euro-cents worth. I have a K&N.
#8 jib
jib
    USMB is life!
  • 173 posts
  • Seattle
Posted 25 October 2005 - 11:57 AM
This one will be argued long after we are all dead. Both sides have huge volumes of data proving they are right. Choose whichever makes you happy.
Personally, I used a K&N for over 250k in my recently totaled 1988 Saab 9000S. It used less than a half quart of oil between it’s annual oil changes (12-15k miles), didn't smoke ever and passed emissions tests every year without any preparation. This is a testament to Mobil 1, clean air coming in to the combustion chambers and those Swedes in Trollhatten assembling the engines.
Again, choose the one that lets you sleep at night. It doesn’t really matter that much in the real world. FYI - I do all of my own work on my cars. For me, I buy quality products that help reduce my maintenance costs and labor, without sacrificing MY perceived level of quality.
Jack
#9 Setright
Setright
    Elite Master of the Subaru
  • 3,174 posts
  • Denmark
Posted 25 October 2005 - 03:43 PM
Myths are plentiful.
I have used K&N for many years without problems.
#10 grossgary
grossgary
  • Gold Subscribers
  • 17,909 posts
  • West VA
Posted 25 October 2005 - 04:58 PM
yah, i have 100's of thousands of miles on K&N filters...100's of thousands on the same one in fact with no issues. they last forever.
