kevinsUBARU Posted October 24, 2005 Share Posted October 24, 2005 Snow tire time!!!!!!! I saved a set of 15" steelies from my old 1995 Impreza, and would like to put my snows on them. The current ride is a 2001 Legacy L with 15" steelies as well. I have been searching and have not found the answer to my question: Are the 15" steelies any different from 1995 to 2001? Will this work? Thanks! Kevin Quote Link to comment Share on other sites More sharing options...
Subie Gal Posted October 24, 2005 Share Posted October 24, 2005 bolt pattern and offset are the same they should work just fine. i had impreza steelies on my 99 Legacy.... worked just fine Jamie Quote Link to comment Share on other sites More sharing options...
Strakes Posted October 24, 2005 Share Posted October 24, 2005 They should work. But to be sure, maybe you can jack up one side of your car and put them on the front and rear and test the clearance. Quote Link to comment Share on other sites More sharing options...
kevinsUBARU Posted October 24, 2005 Author Share Posted October 24, 2005 Thank you, I appreciate the help Quote Link to comment Share on other sites More sharing options...
kevinsUBARU Posted January 18, 2006 Author Share Posted January 18, 2006 Working like a charm, but does anyone know the offset for the stock steel rim on a 2001 Legacy L? Quote Link to comment Share on other sites More sharing options...
nickb21 Posted January 18, 2006 Share Posted January 18, 2006 I believe it's 55mm. Quote Link to comment Share on other sites More sharing options...
