Oil Pickup tube
7 replies to this topic
#1 soobscript
soobscript
    needs more time
  • 705 posts
  • Columbus, OH
Posted 25 October 2005 - 12:34 PM
Mine won't come out. I've tried severa Blaster applications, vice grips, and heat. It has only moved a little. I managed to crimp the base some and mess up the mounting edge on the block. Pics attatched.
How do I get it out? Just keep heating and repeating?
I know I'm going to need a new o-ring, but I don't think it was in my seal kit. It should be rubber right? Pic of the rings I'm not sure about attached.
Also, any tips on cleaning the varnish and stuff from inside the block with the case and pistons and all assembled?
--Ed
#2 Ross
Ross
    Can't be bothered
  • 1,865 posts
  • Christchurch, New Zealand
Posted 25 October 2005 - 04:14 PM
I ended up using a cold chisel to get mine out - needless to say, i have to repace it with a new one! It wasn't very expensive.
An auto parts store should have a selection of standard o-rings, take the pickup along and find ones that fits.
#3 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,021 posts
  • East Coast
Posted 25 October 2005 - 04:50 PM
www.thepartsbin.com has the correct oil pump o-ring listed for the EA82 and ER27. they are always very difficult to remove. just keep trying. i ended up getting mine out and reusing it....and mechanic beware, don't plan on reusing that old o-ring. mine was brittle and in horrible shape and fell apart. but i'm thinking that thing is in there so tight i don't know that it could ever leak. it's a tough call, mine was in terrible shape but it was so damn hard to get out i can't imagine it leaking so i still can't decide if i'll replace it next time i have to do one. next time i would install the oring and possibly use some anaerobic sealant in a strategic position as well.
#4 soobmater
soobmater
    Got Mud?
  • 1,668 posts
  • South Bend
Posted 25 October 2005 - 05:18 PM
mine was a pain in the rear to get out...i finally did those, with vise grips and plenty of leverage..
#5 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 25 October 2005 - 06:13 PM
This method works almost every time.
#6 moosens
moosens
    Vintage Subathusiast
  • 1,968 posts
  • Bridgeport CT
Posted 25 October 2005 - 08:49 PM
I asked a long time Subaru mechanic who said lots of soaking,sometimes heat,and almost always a pain in the butt.
#7 soobscript
soobscript
    needs more time
  • 705 posts
  • Columbus, OH
Posted 25 October 2005 - 08:55 PM
I'll keep trying to get it out. Hopefully intact. Vice grips are how it got crimped. Had to make them that tight to not slip with rubber tape and a rag. Now the tube wants to bend at that spot, as if it wasn't tough enough before.
Dealer only wants $11 for a new one, but thealleyboy has one for me :).
Good call on the parts store for o-ring. With my luck trying to find Soob parts around here, no one will have the right size.... Should it be a "hi-temp" or anything?
#8 soobscript
soobscript
    needs more time
  • 705 posts
  • Columbus, OH
Posted 25 October 2005 - 08:58 PM
Correct on all counts. Especially the third.
