Idles High 97 Legacy Outback
3 replies to this topic
#1 Evenstar
Evenstar
    New User
  • Pip
  • 7 posts
  • Boulder
Posted 31 October 2005 - 12:26 AM
Can anyone shed light on it idles really high when I first start it and then when sitting at a light, etc. the idles sometimes is high then calms but not totally quiet like when I first got the car in July. Does the timing belts or head gaskets have anything to do with this. I just had both done. Thanks
#2 oregonloyale
oregonloyale
    User Awaiting Email Confirmation
  • 255 posts
  • salem
Posted 31 October 2005 - 12:49 AM
how high is high?
Idle air control valve.
Do you have a K&N air filter?
Is your check engine light on?
#3 Evenstar
Evenstar
    New User
  • Pip
  • 7 posts
  • Boulder
Posted 01 November 2005 - 12:52 AM
I don't really know how to measure how high, but it sounds really high when starting but not every time. The air control valve has been checked. What is a K&N air filter. I was told at last oil change that filter was fine. I have a new one to put in but not K&N. No engine light problem at this time. It did come on a month or so ago and it stalled out so bad I almost didn't make it home. Then the day I drove it to the mechanic it was fine. They ended up putting a code in that fixed the problem.
Can the new head gaskets or new timing belts have anything to do with the idle?
how high is high?
#4 oregonloyale
oregonloyale
  • 255 posts
  • salem
Posted 01 November 2005 - 01:20 AM
doesnt your catr have a Tach?
if so thatll tell ya how high the idle rpms are.
I doubt you have a head gasket problem.
Any white smoke out the tail pipe?
Is it consuming coolant?
is there white goo under the oil cap?
If no , then no head gasket issues.
