tjs12220 Posted November 9, 2005 Share Posted November 9, 2005 Hello, so i have my 97 legacy LSi, and a few things im getting the throttle position sensor replaced next thursday the 11/17, but this saturday the 11/5 i noticed a grinding noise in the right side, then today a guy said it could be the bearing, the calibar* (i really have no clue what that is) when im going 0-25 is when the grinding noise happens, after that it stops. any suggestions? Thanks! Thomas Quote Link to comment Share on other sites More sharing options...
mtsmiths Posted November 9, 2005 Share Posted November 9, 2005 Could be a brake caliper, a disk wear indicator (do Subarus have those?), dirt stuck in the brakes, a bad wheel bearing, a starting-to-fail CV joint. Take it to a self car was and really spray the helloutta the front brakes. If it goes away it was dirt and you fixed for $1.25, if it's still there someon'e gonna have to look. Quote Link to comment Share on other sites More sharing options...
tunered Posted November 10, 2005 Share Posted November 10, 2005 Hello, so i have my 97 legacy LSi, and a few things im getting the throttle position sensor replaced next thursday the 11/17, but this saturday the 11/5 i noticed a grinding noise in the right side, then today a guy said it could be the bearing, the calibar* (i really have no clue what that is) when im going 0-25 is when the grinding noise happens, after that it stops. any suggestions? Thanks! Thomas the next time you drive the car pay attention when you go around a left hand turn,this loads the rf bearing a little more and the noise should be more noticeable,if not probally the brakes wore down to metal. Quote Link to comment Share on other sites More sharing options...
tjs12220 Posted November 10, 2005 Author Share Posted November 10, 2005 I dont know if this makes a difference but it even makes noises sometimes when i go in reverse? left hand turns, right hand turns it just grinds real bad under 25mph, and then nother after that. Quote Link to comment Share on other sites More sharing options...
tunered Posted November 10, 2005 Share Posted November 10, 2005 I dont know if this makes a difference but it even makes noises sometimes when i go in reverse? left hand turns, right hand turns it just grinds real bad under 25mph, and then nother after that.i dont think you could go fast enough in reverse to hear a bearing,ill go with brakes. Quote Link to comment Share on other sites More sharing options...
