Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Leaky '86 GL 3dr - leaking through fan?
#1
Posted 12 November 2005 - 03:00 AM
Any tips would be great! I hate having passengers stepping in a puddle in my car...
Pics to follow...
*edit*
On a slightly unrelated note, my radiator steams only when it rains. I think it's just water spraying into the front of the rad, but I'm not sure. Anyone else have this problem?
#2
Posted 12 November 2005 - 04:45 AM
#3
Posted 12 November 2005 - 11:07 AM
yes, but i wouldn't call it a problem really.
Which, the steam or the leak? I didn't really think the steam was a problem, but I know for sure the leak is a problem. I don't want water getting into the fan and shorting something out...
#4
Posted 12 November 2005 - 11:18 AM
Also look all around the hodd/air intake/fenders and doors of the car and make sure ALL your body drain hiles are clear ..that will help a lot.
nipper
#5
Posted 12 November 2005 - 11:27 AM
If your talking about water leaking into the heaterbox, you cant stop that. but you can make sure the heaterbox drain hose is not cloged.
nipper
Where is the drain hose for the heaterbox located? Also, I know of the drain holes next to the hood, but how many more are there?
#6
Posted 12 November 2005 - 12:03 PM
do you have ac? if you do, look under the car and you should see a rubber hose sticking down about 1" thats your drain hose.
nipper
#7
Posted 13 November 2005 - 10:53 AM
There are holes in the hood, and inside the fenders ... towards the bottom. They are sort of obvoius once you realize your not looking for holes per say ..gaps that knind of thing, hard to describe. Basically anyplace you can fit a wire coat hanger...
nipper
Found the gaps I think... No AC though, so is there another drain hole? I just can't believe the car is designed so that water can get into the fan...
The foam seal around the flex pipe coming from the fan is slightly damaged, and that's where the water is coming from. There's no way to stop this?
