EJ18 heads on to an EJ22? Anyone done it?
16 replies to this topic
#1 Matty B
Matty B
    Eat, Live, Breath Subaru
  • 342 posts
  • Swansea Tasmania
Posted 13 November 2005 - 05:08 PM
Hi all, as the title says,
I am looking for a compression gain for a major power increase.
My car runs LPG and they love high compression.
Ant help would be greatly appreciated.
Cheers,
Matt
#2 AlpineRaven
AlpineRaven
    USMB is life!
  • 187 posts
  • Australia
Posted 14 November 2005 - 05:42 AM
Cheers,
Matt
I've been asking SAME question for long time, no one seems to know as far I know, I don't wanna gamble if it doesn't work.
I wanted to get EJ18 SOHC and fit it on EJ22 for increase of compression, won't be much but noticeable in theory.
Cheers
AP
#3 Dr. RX
Dr. RX
    Elite Master of the Subaru
  • 9,984 posts
  • Sammamish, WA
Posted 14 November 2005 - 07:46 AM
I don't know why they wouldn't, they are basically the same engine. I know people who have installed EJ22s into a car that had an EJ18 in it, they had to use the EJ18 intake manifold, so I know there is no difference there.
Why do you feel that the EJ18 heads will give you high compression? Does it have fewer cc's (in the compustion camber area of the head) then the EJ22 heads? Or is it the pistions that are giving teh EJ18 higher compression?
#4 blitz
blitz
    Banned
  • Banned
  • 1,091 posts
  • Warren, Michigan
Posted 14 November 2005 - 11:22 AM
EJ-18
BORE 87.9mm
STROKE 75mm
EJ-22
BORE 96.9mm
STROKE 75mm
I can't seem to dig up any combustion chamber volume specs, but both engines are running the same block with the same stroke, only the bore dimension is different. I'll make that leap to rump roast-u-me that the EJ-18's chamber would have a slightly smaller diameter to match the smaller bore of the EJ-18 piston.
Math isn't my strong point, but since the 2.2 piston is pushing 1.215 greater displacement upward the same distance means that it would increase the CR by 1.215?
If so, that would bump a 9.7:1 CR up to 11.8:1
Unless I missed something, that doesn't seem too shabby.
#5 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 14 November 2005 - 01:21 PM
check out www.bbs.legacycentral.org
Matt Monson should be able to answer your question. I believe the ej18 heads will increase your compression ratio, by how much I don't know.
Another thing to note is the EJ18 has slightly smaller valves too. I don't recall if it was just the intake or exhaust, or both.
#6 Matty B
Matty B
  • 342 posts
  • Swansea Tasmania
Posted 14 November 2005 - 08:14 PM
Thanks for the help guys, yes its posssible, yes the valves are smaller, yes I am giving it a go.
From what my Gas Guru has been telling me, a 20% increase in compression will get me a 40% increase in HP.
Its to do with the specific burn rate of LPG.
I will post results as soon as its running.
Cheers all,
Matt
#7 AlpineRaven
AlpineRaven
    USMB is life!
  • 187 posts
  • Australia
Posted 15 November 2005 - 01:55 AM
Cheers all,
Matt
Yeah that sounds about right, let us know how you went and see if you do save on fuel etc... see if you came any problems etc, could you keep us informed.
Cheers
AP
#8 88HatchMonster
88HatchMonster
    Back in the Hatch
  • 486 posts
  • South Burlington, VT
Posted 15 November 2005 - 02:14 AM
I read a bunch of his posts, Matt Monson is vehemently against using the EJ18 heads on an EJ22 because he says they "flow like crap."
But... he's never done it I don't think, and as far as I know no one else has, either. At least no one who has posted the results to a forum.
I've been debating the same issues you have, but I'm leaning toward doing the head swap anyway. For me, the power increase over the full RPM range from a boosted CR should outway the downfalls of limited flow, since it's going into an offroader and not a street screamer.
#9 Bmm001
Bmm001
    USMB is life!
  • 205 posts
  • Lancaster County
Posted 15 November 2005 - 09:07 AM
You might get higher compression, but, as hatchmonster says, they don't flow as well. Wouldn't that make the increase negligible? As far as I understand, the heads on the EJ22 are an improvment over the EJ18 ones, so wouldn't reversing them be going backwards in terms of performance?
Brian
#10 offroadsubaruguy
offroadsubaruguy
    Subaru Nut
  • 729 posts
  • arvada, colorado
Posted 15 November 2005 - 09:30 AM
just do a port and polish, and a valve job, replace the old valves with newer ones from a 2.2 im sure you could do it...... it would just take money...
#11 88HatchMonster
88HatchMonster
    Back in the Hatch
  • 486 posts
Posted 15 November 2005 - 11:57 AM
PnP + valve job = way more money than I want to spend. I may PnP myself but I the valves are still going to be a bottleneck.
My point is that lugging around at lower RPM I'll still have a power increase even if the engine gets choked up at higher RPM/More throttle. So the swap might work for me in my offroad hatch, whereas I would not want to run it in my impreza...
#12 blitz
blitz
    Banned
  • Banned
  • 1,091 posts
  • Warren, Michigan
Posted 15 November 2005 - 12:15 PM
Along with the smaller valves choking the top-end HP, you'll be condending with the EJ-18 cam.
As you say, the combo of tall compression and small ports will will give you tractor torque between 2000-3000 RPM.
#13 subeman90
subeman90
    Soobologist
  • Moderator
  • 2,802 posts
  • Akron PA
Posted 15 November 2005 - 01:16 PM
is there a difference in cams between the 2.2 and the 1.8? I'm interested in this swap down the road in my imp.
#14 cookie
cookie
  • 3,058 posts
  • SFO
Posted 15 November 2005 - 01:26 PM
I have run LPG in trucks and we used to raise the compression. I suspect the smaller valves will easily be offset by the extra power in LPG use.
This is not something I would do on a US street car because gas is getting worse and high compression can be a problem without reprogrammed electronics. The other reason is that reducing the size of the valves reduces potential top end power with gas.
#15 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,271 posts
  • Everett, WA, USA
Posted 15 November 2005 - 01:59 PM
Would the 2.5 head work? that might raise compression too, and flow better than the 1.8
#16 88HatchMonster
88HatchMonster
    Back in the Hatch
  • 486 posts
Posted 15 November 2005 - 02:07 PM
2.5 heads on a 2.2 block will result in lower compression.
The mod that I guess really works great is 2.2 heads on the 2.5 block. Good flow, higher compression, beastly motor.
#17 blitz
blitz
    Banned
  • Banned
  • 1,091 posts
  • Warren, Michigan
Posted 15 November 2005 - 02:33 PM
I'll admit my cam comment was conjecture, based on the smaller displacement motor having different (lesser) airflow requirements.
I could be completely wrong.
