n00b w/ 87 xt needs help!
6 replies to this topic
#1 juztin
juztin
    New User
  • Pip
  • 2 posts
  • McDonough
Posted 16 November 2005 - 02:46 PM
hi all! i just bought a 1987 xt DL, non-turbo, and i've got so many questions....
first, how can i tell if it is 4WD? when i took it to the shop to have the muffler changed, he said it was "all wheel drive", but i want to make sure...
also, i've got a small leak somewhere...at first i thought it was coming from the CV boot alone (because it's busted, to be repaired soon), but the same shop that changed my muffler said that it wasn't coming from the CV boot because it was oil, not grease....i've been steadily checking my levels, and it appears that my oil level isn't dropping, but my gear oil level is...however, i've yet to pinpoint the spot the leak is coming from. are there some common spots i could check that this leak would be coming from, or ways to determine if it is in fact gear oil?
thanks in advance!
#2 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,271 posts
  • Everett, WA, USA
Posted 16 November 2005 - 02:50 PM
If you have an Orange 4WD button on your shifter, you have 4wd, not awd, i don't believe the XT DL's came with AWD, as far as your leak, do you have an auto or a 5 speed?
#3 juztin
juztin
    New User
  • Pip
  • 2 posts
  • McDonough
Posted 16 November 2005 - 02:52 PM
ok, there's no buttons on my shifter, so it's not 4WD...
as far as the transmission, it's a five speed.
#4 Jerry DeMoss
Jerry DeMoss
    Pushrods 'O' Fury
  • 2,408 posts
  • Colorado
Posted 16 November 2005 - 02:55 PM
If there is anyway possible you could jack it up on a lift and pressure wash the under side that would be a good start to tell where it's coming from.
#5 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,756 posts
  • East Coast
look under the car - if you have rear axles to the wheels then you have 4WD or AWD. if there's nothing, then you fot FWD.
best to clean the underside really good and see where the leak comes from, see what starts getting oily first.
#6 idosubaru
idosubaru
  • 23,756 posts
  • East Coast
Posted 16 November 2005 - 02:56 PM
for XT or Xt6 specific info www.xt6.net is a good resource as well. for your motor and trans and most things you'll get all you could ask for here though, much larger membership base.
#7 NoahDL88
NoahDL88
  • 4,271 posts
  • Everett, WA, USA
Posted 16 November 2005 - 02:57 PM
This would be the easiest.
Just a helpful hint, leaks almost always start the farthest forward and the highest up. so a leak on the top of the engine can look like a flood from the transmission.
