Interference Engine?
3 replies to this topic
#1 [HTi]Johnson
    Head Trauma, inc.
  • 1,522 posts
  • Coburg, Or.
Posted 18 November 2005 - 02:56 AM
Hello, is an Engine in a 1998 Outback isn't an interference is it. I don't think it is and was just making sure. Oh, what does the pulley, on the lower left side of the crank do(It's part of the timing belt system)? Is it the oil pump. I'm asking these questions for someone who has mechanics telling them that there motor is shot because the pulley sheared off the, what I think is the, oil pump.
Thanks, Justin.
#2 Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 18 November 2005 - 03:27 AM
The 98 only came with interference engines to my knowledge. The EJ25 has always been one, and if they offered the EJ22 in that car, it's interference after 96.
#3 NOMAD327
    Eat, Live, Breath Subaru
  • 343 posts
  • danville, PA
Posted 18 November 2005 - 06:39 AM
oil pump is dead center surrounding the crankshaft, the lower driver's side pulley is the water pump. If the water pump locks up, the engine will skip time and have internal damage.
#4 ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 19 November 2005 - 02:48 AM
If you are facing the timing belt and oil pump there are 2 idlers to the passenger side that are just that, idlers.
The metal casting that holds those two are part of the block so if you shear one off the block is likely junk. There are 3 things the belt passes on in the drivers side of the block, the cogged idler, the tensioner bearing and the water pump. These are all part of their own separate casting and can be replaced without the block being junk.
