Is a cruise control from an 88 hatch comapatble with a 84 Brat?
4 replies to this topic
#1 AKIRA
AKIRA
    USMB Reverend
  • 618 posts
  • Jersey Shore (Central) PA
Posted 01 October 2003 - 05:54 PM
Hello, Phatbrat has a cruise control from an 88 hatchback he can sell me and I want to know if it will work on an 84 Brat GL?
so, will it?
thanks.
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 22,071 posts
  • Portland
Posted 01 October 2003 - 07:01 PM
There are several types of CC used in the EA81's. I would make sure the kit fits both styles of dash's - there's tilt wheel, and non-tilt wheel style's. Also - since it's for an 88, the wiring may be slightly different, but I'm sure that it's doable in that respect. What type of carb does your 84 have? I don't know if there is anything specific throttle linkage wise, but if you have the carter / weber single barrel, then you might have problems (I don't know for sure), cause the 88 surely had a hitachi. I think the carter / weber only came on *some* 83's and 84's. Some 84's came with factory CC, and I've seen one 83 with what looked like a dealership install. I'm guessing that this kit has a on/off switch that lights up - and goes under the dash - like the third eye switches. That's the one I saw that looked like a dealer install. The factory one has a different housing around the column, with on and off switches you access thought the steering wheel.
#3 PHATBRAT
PHATBRAT
    Subaru Lover
  • 2,628 posts
  • Berwick, PA
Posted 01 October 2003 - 08:01 PM
Yeah, This one has the button like the "passing light". The instruction sheet says for a GL with manual transmission. SOA part # is : SOA460550
#4 AKIRA
AKIRA
    USMB Reverend
  • 618 posts
Posted 01 October 2003 - 09:53 PM
I will ask a person I know at kinelys subaru whether it fits
#5 PHATBRAT
PHATBRAT
    Subaru Lover
  • 2,628 posts
  • Berwick, PA
Posted 01 October 2003 - 10:17 PM
Yeah, KINLEY's should know. They know their SH**!!! If not them, ask Jeff or Gary from W and L in Northumberland. Boz
