kristiangl10 Posted November 20, 2005 Share Posted November 20, 2005 Hi Everybody, I have subaru gl-10 89 2WD Turbo and need to replace thine black hose going from thermostat somewhere in the middle of the engine. (Like under the turbo or something) The access is insane. Thermostat site is OK. but the other end is totaly screwed up. Look's like I have to take engine apart or something. Could someone tell me what exactly I have to do to replace the hose. Thank you so much. Kristian Quote Link to comment Share on other sites More sharing options...
soobme Posted November 20, 2005 Share Posted November 20, 2005 This is coverd in the USRM (link @ top of fourm) under "10mm hose from hell" or somthing like that. U will need forsepts or somthing simalr to do it. Have FUN:brow: P.S. Ultimate Subaru Repair Manual= USRM Quote Link to comment Share on other sites More sharing options...
MilesFox Posted November 20, 2005 Share Posted November 20, 2005 the coolant line is the skinny hose off the bottom of the thermostat housing and it goes to the top of the block. if you are referring to the hose off the black part that is an air hose and it goes under the intake plenum (part with "turbo" cast into it) you can take up the plenum by loosening the hose clamps on both sides once you take that up you can access the coolant hose that runs af=cross to the top of the turbo Quote Link to comment Share on other sites More sharing options...
kristiangl10 Posted November 21, 2005 Author Share Posted November 21, 2005 HI, I'm talking about black cooling house which goes from thermostat under the Turbo. Should I loose just those two clamps? I can see many things in my way. Looks like it's not easy to fix. Could you write me more about that. Thank you Kristian the coolant line is the skinny hose off the bottom of the thermostat housing and it goes to the top of the block. if you are referring to the hose off the black part that is an air hose and it goes under the intake plenum (part with "turbo" cast into it) you can take up the plenum by loosening the hose clamps on both sides once you take that up you can access the coolant hose that runs af=cross to the top of the turbo Quote Link to comment Share on other sites More sharing options...
MilesFox Posted November 21, 2005 Share Posted November 21, 2005 the picture shown above is withthe plenum removed. you dont have to take off the air filter boot or anything like that with the aluminum turbo plenum taken up you will have access to the air hose, the coolant hose, and the throttle cable, and ecu temp sensor just take up the 2 hose clamps. the plenum will still be connected to the air hose on the black piece aboce the thermostat housing, you can either take off the hose or just swing the plenum out of the way Quote Link to comment Share on other sites More sharing options...
kristiangl10 Posted November 21, 2005 Author Share Posted November 21, 2005 OK, thank you for info. I just saw the ther answer and they did make everything very difficult so I was very confused about that. Thank's now K. the picture shown above is withthe plenum removed. you dont have to take off the air filter boot or anything like that with the aluminum turbo plenum taken up you will have access to the air hose, the coolant hose, and the throttle cable, and ecu temp sensor just take up the 2 hose clamps. the plenum will still be connected to the air hose on the black piece aboce the thermostat housing, you can either take off the hose or just swing the plenum out of the way Quote Link to comment Share on other sites More sharing options...
