Loosening stubborn oil drain plug...
15 replies to this topic
#1 leej323
leej323
    USMB Regular
  • PipPipPip
  • 30 posts
  • Los Angeles
Posted 21 November 2005 - 10:53 PM
Anyone have some techniques for loosening a stubborn oil drain plug? The damn thing won't budge. I swear I was hanging by my wrench underneath the car. :banghead:
No power tools or breaker bar at my disposal...
Thanks!
#2 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,271 posts
  • Everett, WA, USA
Posted 21 November 2005 - 10:56 PM
Tap the end of the plug, like you were driving a nail, not full blows, but some love taps, and then try and tighten it, but not a lot, then it should let go and free up.
#3 leej323
leej323
    USMB Regular
  • PipPipPip
  • 30 posts
  • Los Angeles
Posted 21 November 2005 - 10:58 PM
Hmm... I'll try that. Thanks
#4 Subarian
Subarian
    1000+ Super USER!
  • 1,150 posts
  • Orem
Posted 21 November 2005 - 11:31 PM
If you have a combination wrench, you can put the box end on the bolt. Then use another box wrench and slip it over the open end of the wrench. That will allow you to approximately double your torque on the wrench. Alternately, you can use a cheater bar. It's just a length of pipe that will slip over your wrench handle and allow you to apply more leverage. I have several different lengths. It works best if your wrenches have a good warranty.;)
#5 nkx
nkx
    Rallycross Junkie
  • 891 posts
  • Carlisle, PA
Posted 22 November 2005 - 04:31 AM
a $5 1/2" drive 12" breaker bar and a 3' long piece of 1x1 box steel will coherce pretty much any bolt out with little effort on your part.
#6 86subaru
86subaru
    Elite Master of the Subaru
  • 3,097 posts
  • ohio
Posted 22 November 2005 - 06:09 AM
does your subaru have a skid plate ,if so remove it first ,much easier to gey to plug, i found that out
#7 Dan Olsen
Dan Olsen
    New User
  • PipPip
  • 15 posts
  • Plattsmouth
Posted 22 November 2005 - 07:06 AM
umm yeah...cheeter bar.... = lots and lots of pain.... i broke a 1" drive breaker bar using a cheeter bar... landed 15 feet away.... decided it was time for a lunch break after that.... suppose a smalll one on a car bolt isn't a bad idea tho... good luck....
dan
#8 pattiandruss
pattiandruss
    New User
  • PipPip
  • 22 posts
  • Klamath Falls
Posted 22 November 2005 - 08:47 AM
I had to take out one that had been super tightened and rounded off by a quickie oil change place. Used a pipe wrench, but you will have to get a new plug afterwards. Do this as a last resort. Russell
#9 fredrogers
fredrogers
    USMB Regular
  • PipPipPip
  • 106 posts
  • St. Anthony
Posted 22 November 2005 - 02:32 PM
What about some PB blaster?
I have had good luck with that and stubborn bolts.
-=fred=-
#10 leej323
leej323
    USMB Regular
  • PipPipPip
  • 30 posts
  • Los Angeles
Posted 22 November 2005 - 03:48 PM
Yeah, took off the skid plate. About to try this again...
#11 BlueTrain
BlueTrain
    Subaru Fanatic!
  • 477 posts
  • MisSOULa
Posted 22 November 2005 - 04:07 PM
you sure you're turning it the right way? :grin: actually i was over at a friends a few months back and he was reefing on his drainplug and i looked underneath and he was turning it the wrong way.. sooo it does happen.. lol
#12 robm
robm
    Subaru Nut
  • 933 posts
  • Terrace, B.C.
Posted 22 November 2005 - 04:26 PM
Vise grips and a hammer. With any luck, it won't do as much damage as a 12 pt combination wrench slipping on the hex of the plug.
To prevent this, change the crush washer. They last for about 3 oil changes before they get too flat to seal, and then the torque requirements on the plug get so high that it becomes way too much work to remove.
#13 Subarian
Subarian
    1000+ Super USER!
  • 1,150 posts
  • Orem
Posted 22 November 2005 - 06:39 PM
Whatever you do to get it out, let us know. The suspense is killing me!:lol:
#14 subiemech85
subiemech85
    SIX STAR SERVICE
  • 2,710 posts
  • down by the river
Posted 22 November 2005 - 10:18 PM
I use a IIRC 17mm 6pt socket and wratchet or 6pt wrench
and a hammer to tap the tool to loosen, it works, BTDT
#15 leej323
leej323
    USMB Regular
  • PipPipPip
  • 30 posts
  • Los Angeles
Posted 22 November 2005 - 10:29 PM
Haha, got it out. But not by any of the ways mentioned above. Maybe a combination? :D
I tried spraying some WD-40 on it and waiting for a bit. Got back under and pulled/pushed away... no luck. I even tried tapping the wrench with a hammer to hopefully gain some slack... still nothing.
I was about to give up but decided to try using my 12" socket wrench and pull while on two feet from in front of the car. I swear I was about to pull the car off the jackstands and just like that the plug came loose.
Had to go out and buy a set of oil filter pliers to pull out the filter, but that's the easy part. I want a beer now. :drunk:
Thanks again for all the suggestions!
#16 fredrogers
fredrogers
    USMB Regular
  • PipPipPip
  • 106 posts
  • St. Anthony
Posted 23 November 2005 - 09:47 AM
I am glad you got it off. :drunk:
That would suck to not be able to change your oil.
-=fred=-
