Startup hesitation
14 replies to this topic
#1 bfg9k
bfg9k
    USMB Regular
  • PipPipPip
  • 100 posts
Posted 22 November 2005 - 05:55 PM
This morning was a repeat of something that happened a few months ago. I turned the key to start the car ('98 Legacy, auto, 113k miles)...and for an instant (1/2 second at most) nothing happened. Then the ignition kicked in and it started right up as usual.
Is this a harbinger of starter/ignition solenoid/ignition switch/etc trouble down the road?
#2 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 22 November 2005 - 06:19 PM
doubt its an ignition switch. First thing first clean your battery and where they terminate.
#3 bfg9k
bfg9k
    USMB Regular
  • PipPipPip
  • 100 posts
Posted 22 November 2005 - 06:54 PM
Oops, it happened again this evening with the engine warm.
I will clean the battery tomorrow.
#4 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
Posted 22 November 2005 - 10:04 PM
I had the same thing happened to my gtp. Never figure it out and eneded up selling before I actually got it checked out by a pro. I always thought it was just a weak battery, but it started fine once it decided to; which was about a second after the key was in the start position
#5 subaru girl
subaru girl
    USMB Regular
  • PipPipPip
  • 39 posts
  • Linden
Posted 22 November 2005 - 10:12 PM
i had the same problem. i would have to turn the key a few times for it to work. ended up being the starter. just before i got it replaced it stuck on and kept cranking the car even with the key off
#6 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 23 November 2005 - 12:56 AM
could be a starter, my legacy did it, but it was cables. at least we are all in the same ball park.
nipper
#7 bfg9k
bfg9k
    USMB Regular
  • PipPipPip
  • 100 posts
Posted 23 November 2005 - 03:16 PM
Thanks for the responses! I have decided to do a 'wait and see' since the car is starting up normally today. I think a diagnosis will be more successful if the problem happens either frequently or predictable.
#8 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 23 November 2005 - 04:12 PM
You know the best way to make it never happen again. Buy a starter and keep it in the car .... murphys law :brow:
nipper
#9 bfg9k
bfg9k
    USMB Regular
  • PipPipPip
  • 100 posts
Posted 26 November 2005 - 02:44 PM
nipper
Naw, if I buy a starter the battery will go :dead:
#10 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 26 November 2005 - 03:03 PM
heheeh always a pessamist :)
If you claena the cables and it happens again replace the starter. There may be a dead spot int the winding, and next thing you know is you have an emergency hammer to hit the starter with to get it out of that dead spot.
nipper
#11 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,042 posts
  • Honolulu HI
Posted 26 November 2005 - 03:35 PM
Before you throw money away on a new starter:
It's most likely the copper contacts inside the starter's solenoid. Cheap parts and not too difficult to replace, although you do have to take the starter out to do it.
Do a search--procedure has been discussed a lot.
#12 luv2lean
luv2lean
    New User
  • Pip
  • 7 posts
  • norcal
Posted 29 November 2005 - 12:22 AM
I have a 99 legacy with similar miles and starter issues. As has been said, the starter soleniod contacts are the likely problems. After searching the board here, i decided to take the starter out and inspect the contacts. It is really quite easy to replace the contacts once the starter is removed. I was fortunate to have a local auto electric shop (Lehr auto electric in Sacramento) that stocks unusual parts like the copper contacts which cost less that $3 and also carried the solenoid plunger for $22 which is the other part that is likely worn and should also be replaced. After doing some research here and talking to Lehr, I am convinced these are most often the only parts that are replaced when these units are rebuilt and sold for about $100, and the starters otherwise last a very long time. If you are at all mechanically able, i would buy/order the contacts and plunger, then remove the starter and replace the parts.
#13 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 29 November 2005 - 12:50 AM
well not really. The starter is totally disassembled. Those parts are replaced, along with the starter drive and drive bushings. The starter motor windings are tested and replaced if found to be out of spec. There are a few more peices to the start then you see there. personally i just replace the starter, because, the next thing to go is the one way clutch in the drive.
nipper
#14 Commuter
Commuter
    Subaru Master
  • 1,857 posts
  • Niagara area, Ont Canada
Posted 29 November 2005 - 01:04 PM
The early / mid 90's Subarus were noted for having the contacts in the starter fail / wear out. There were quite a few posts about that a few years back on the board. Inexpensive to fix if you are willing to spend a little time opening up the starter. Given the passage of time, it could now be happening in the late 90's vehicles. Granted, I haven't seen too much mention of it, so I suspect that the late 90's starters are better in this regard than the early / mid 90's ones were.
Commuter
#15 bfg9k
bfg9k
    USMB Regular
  • PipPipPip
  • 100 posts
Posted 30 November 2005 - 12:44 PM
Yeah, this is my thinking too, if I can get away with crawling under the car once vs. many times I'll go for once.
Anyway, the problem has yet to rear its ugly head again, so I am adopting a wait and see approach. And now the *&$!# 4EAT transmission refused to shift into 4th gear the other day, but only once so it's nothing I can attempt to get fixed...
