Help - changing headlight bulb
3 replies to this topic
#1 davesunra
davesunra
    New User
  • Pip
  • 2 posts
  • Bolton
Posted 24 November 2005 - 02:18 PM
OK, I'm lame. How do you change the front headligt bulb in a 2002 Forester?
Dave
#2 tunered
tunered
    Subaru Fanatic!
  • 424 posts
  • vincent,ohio
Posted 24 November 2005 - 02:33 PM
Dave
not familar with your model but basics are probbally the same. there should be a plastic sleeve where your wires run into light,twist sleeve counter clockwise,this will let pull light bulb out[might have to twist because of o-ring] unplug wires.
#3 frag
frag
    Soob shade tree mechanic
  • 1,777 posts
  • Montréal, Québec, Can.
Posted 24 November 2005 - 02:40 PM
ON my 96 Legacy, you first pull on the connector straight out, then remove the big rubber bellows (note that there is a «this side up» indication), then there is a spring wire that you unlock (look closely it's intuitive) and then you pull the bulb out. Take care not to touch the fresh bulb's glass with bare fingers. Take care also to insure that the rubber bellows is correctly reinstalled cause it's responsible for sealing the inside of the head light enclosure against humidity.
Hope that helps.
#4 davesunra
davesunra
    New User
  • Pip
  • 2 posts
  • Bolton
Posted 26 November 2005 - 07:48 PM
Hope that helps.
Frag, thanks for you help. Had to also remove the battery to gain assess.
~Dave
